The people that have 2 steps, how are you activating it? Right now I have mine on my clutch switch but my clutch engages so high that by the time I try to slip the clutch its on rev limiter. When I bought the car it use to have the engagement switch on its own button but I did not like that. Im thinking I may have to take it back to that.
Anyone have any ideas on how this should be done? I need to leave on the 2 step to build boost.
A friend of mine from the Honda world suggested somehow wiring it into the speed sensor so once the car starts moving the 2 step would stop. I like that idea but have no clue how to do that or if its even possible
Lingenfelter has a speed switch.
That could trigger the two step based on speed.
Not 100% sure just think I have seen something like that before that they offer.
I had mine hooked to a WOT style switch that was mounted on the side of my shifter and used my thumb to hold the switch while launching. It worked perfectly and I could release it whenever I pleased!
Haha this is your old car Shoaf. I just couldn't get that down. My mind goes dumb when trying to do 3 separate things. I can only do 2 max Im still trying to get it to 60 ft like you did. Gotta get that driver mod you had
It uses the accelerator pedal position sensor signal and the cruise control clutch switch. Press the clutch and go WOT to start the 2-step and if you're already WOT and hit the clutch pedal at all it starts the no lift shift feature.
