Fuel pump/system to support 1000whp with E85?
What are the options in a C6Z to support 1000whp with E85. Additional pick ups in the tank to supply enough fuel to the pump?
I built my own using a Magnafuel external pump. Made 937+whp on E85. I have a build thread with the details, it's more of a basic setup, nothing fancy and uses some OEM stuff, but it's pretty affordable and works really well.
ECS style kit with big external or Fore triple hat/etc with good pumps. I would do the fore kit as I don't trust the stock z06 pump on e85. I would call Matt@FSP and get some triple 320 fore setup with ID1300s.
As mentioned. Fore intank or the ecs stage 3. Dropping the tank is a mission so the simplicity of the ecs unit is the stock intank but as unreal suggested...check it's e85 capacity
ru saying theres a fuelpump that you dont have to drop the tank. My situation is my current pump works fine buttttttt its not enough, under boost it starts to fall about 12 psi.
