C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Spark plug options
Old Mar 27, 2014 | 08:19 AM
scottg's Avatar
scottg
Default Spark plug options
2008 ls3 Maggie Heartbeat 514 rwhp 470rwtq.6sp manual. Will be putting ARH 1 7/8 and 3 inch all the way back to stock mufflers npp. Question is what spark plugs do you use with my set up. Looking for 540rwhp when done. ngk6 maybe?
Old Mar 27, 2014 | 08:35 AM
old motorhead's Avatar
old motorhead
Those or the ZR1 plugs will work fine at mild boost. With the headers, are you going to pulley down to get your boost back?
Old Mar 27, 2014 | 08:48 AM
scottg's Avatar
scottg
Not now going slow on upgrades seeing if I like it this way.I don't know if magnuson really has one yet?
Old Mar 27, 2014 | 11:17 AM
george536's Avatar
george536
I was reading into plugs last night, i think im going to try the ngk br6ef, which is the same as the tr6 without a projected tip.
Old Mar 27, 2014 | 01:17 PM
scottg's Avatar
scottg
George536
What is the advantage? more clearance to piston.
Old Mar 27, 2014 | 01:37 PM
FederalPerformance's Avatar
0FederalPerformance
Former Vendor
Brisk Spark Plugs are your #1 choice for sure part# dr14ys (silver tip) would be your best option but if you choose NGK go for something in the 7 heat range to play it safe.
Old Mar 27, 2014 | 03:36 PM
george536's Avatar
george536
George536
Id have to find you the links i read last night because id probably get something wrong trying to say it back lol, but what sold me was that the plug comes with a smaller gap already with a smaller ground strap, instead of trying to rainbow in the tr6 for a smaller gap.
Old Mar 27, 2014 | 03:59 PM
scottg's Avatar
scottg
Good to know will talk to my tuner about that. I have little power compared to others in this section.
Old Mar 27, 2014 | 08:18 PM
Streetk14's Avatar
Streetk14
Magnuson has a ton of pulley choices for the Heartbeat now. 105mm-81mm in 3mm intervals. If you're going to have it re-tuned, you might as well pulley it down to get the boost back to where it was.
For plugs I'd run the OEM ZR1 iridium plugs. You're right in stock ZR1 power range and I think there are some reasons to stick with an OEM style plug. Low maintenance is one.
At your power level, I wouldn't do a "7" range plug, but that's just me.
Old Mar 27, 2014 | 10:21 PM
old motorhead
Yep, you can go overkill with the "cool" plugs. That can get you less than perfect manners for no reason. I've had less than perfect results with the tr6 plugs too. At mild boost levels, use the ZR1 plugs.
If you're going to need a tune tweak anyway, get you an 87mm pulley and enjoy the power. Boost should be around 9 to 9.5 psi with the long tubes. With a good tune and plenty of fuel, you won't have motor troubles. 580ish rwhp and a permagrin is easily done
Old Mar 28, 2014 | 06:24 AM
scottg's Avatar
scottg
Hi Oldmotorhead
Tuner said if I pulley down I"d have to go with new injectors and z06 pump. 2000 and since its in already it would save $450 for a tune later .don"t have the extra $2000 for that now. Will look at stock zr1 plugs, should work good in my car.
Old Mar 28, 2014 | 10:34 AM
Streetk14's Avatar
Streetk14
Hi Oldmotorhead
I could be wrong, but the LS9 injectors that come with the Heartbeat should be enough for a bit more power. I'd think they would be good for at least 600 whp. I guess I'll find out soon enough here as I plan to push mine fairly hard.
Fuel supply on the other hand may be an issue. You'll at least need a boost-a-pump if you don't have one. A Z06 pump would be the other way to go.
Old Mar 28, 2014 | 06:57 PM
scottg's Avatar
scottg
You know I never asked how big the injectors were that came with the Heartbeat. but the big cost is the zo6 fuel pump. And I read enough threads on fuel pump installs to know its over my head. The question I will ask magnuson is how far down can I go without fuel pump or just how big are the stock kit injectors in the ls3 kit?
Old Mar 28, 2014 | 09:16 PM
getburnt's Avatar
getburnt
ECS stage one fuel system is $800 and good to 800hp. Easy install as well minus drilling a hole in your gas tank lol
Old Mar 30, 2014 | 11:32 AM
Streetk14's Avatar
Streetk14
The Heartbeat blower comes with OEM ZR1/LS9 injectors. Some of the ZR1 guys are claiming they're good up to 700 whp, but the ZR1 has higher fuel pressure that probably helps with that. Still, I don't think 600-625 whp would be an issue with those injectors.
The most popular FI kits for the C6 (ECS and A&A come to mind) come with a boost-a-pump to supply the extra fuel. Some people may not like the BAPs, but I've found them very reliable if installed properly.
I'm actually surprised that Magnuson is selling this system without any kind of fuel pump upgrade. I'd be curious to see what your fuel pressure looks like right now on a WOT pull.
Old Mar 30, 2014 | 05:51 PM
scottg's Avatar
scottg
I have no Idea if my fuel pump would work on just one step down I wish Magnuson rep would chime in on this one. I will be calling them in the morning. 2008 ls3 3lt base coupe 6sp manual I"am on file there. Doug Rippie put it in. june of 2013
Old Mar 30, 2014 | 07:02 PM
Streetk14's Avatar
Streetk14
I honestly don't think they'll be able to tell you much. They designed the system to work on a stock engine at a given boost level. The only real way to know would be to hook up a fuel pressure gauge (I'm guessing you don't have any on-board gauges) and make a high rpm pull.
Magnuson has always supplied a fuel pump booster with their older kits, which is why I think it's strange that they don't with this one. I'd think it would definitely be needed if making any more power than you are right now. Even adding headers could push it over the edge.
I have an extra Kenne Bell BAP sitting here if you want it for a good price. The wiring is all done and it's set up to be used with a Racetronix harness (http://www.racetronix.biz/itemdesc.a...%2D008&eq=&Tp=), which is the only way to go. I took the BAP off my '08 when I had it to upgrade to the 20 volt "competition" version. I actually forgot I even had it or I would have used it on my new GS build. It'll give you the headroom you need for more power and is a much easier install than a fuel pump upgrade.
To Spark plug options
