C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
05 diff to 06 diff
Old Apr 16, 2014 | 02:07 PM
AnthonyH123's Avatar
AnthonyH123
5th Gear
Default 05 diff to 06 diff
Broke my 05 diff need to upgrade to the 06 diff. Need advice about whether to get a up graded to stage two or three rear end. The car will not be tracked. But it is supercharged and can and heads don't know the hp. Thanks.
Old Apr 17, 2014 | 10:16 AM
Dtownbrown's Avatar
Dtownbrown
If you need another stock 05 diff I have one. And not sure if you know but a 06+ rear diff is not a direct bolt in.
I used a c5 diff and upgraded my trans main shaft to a 5310 hardened shaft with 300m half shafts in diff. Has supported over 700hp on track and street for over a year.
Old Apr 17, 2014 | 10:51 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I used a C5 diff as well when my '05 diff cracked. Way cheaper. I have an extra stanger adapter bracket too if you decide to go that route.
Old Apr 17, 2014 | 01:39 PM
JackLS1R1's Avatar
JackLS1R1
What trans you guys running that broke their 05 diffs? A4 or M6?
Old Apr 17, 2014 | 02:05 PM
AnthonyH123
5th Gear
M6. wheel hop is what cause the break.
Old Apr 17, 2014 | 02:24 PM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
I swapped out my '05 diff. to a '06 diff. by using this transmission case adapter + a set of new C5 Z06 axles.
www.zip-corvette.com (Item No. MT-447)
Old Apr 17, 2014 | 03:18 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
You had better pull that trans apart and check the output shaft. You have to chuck it up on a lathe and measure the center bearing journal. If it is more than .003 of runout you will need to replace that before installing a new diff. If not you will end up having a pinion bearing failure on the new diff.
You can't measure the runout on the outputs shaft with it in the trans.
Old Apr 17, 2014 | 03:42 PM
saplumr's Avatar
saplumr
I went to a Z diff from RPM. My mainshaft snapped off so trans repair went along with it.
Old Jul 20, 2021 | 12:53 PM
slow_vettec6's Avatar
slow_vettec6
By searching the link it states it's for a manual transmission, will it fit in the auto transmission? Definitely interested in making the upgrade.
To 05 diff to 06 diff
