C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E force sc needs more boost/hp! Help!
Old Apr 21, 2014 | 10:05 AM
NASTY VETTE's Avatar
NASTY VETTE
Default E force sc needs more boost/hp! Help!
Hey Corvette forum, I recently had a E Force 554hp Kit installed in my 09 ls3 auto along with LG 1 7/8 cat less headers and a 3.5" pulley.
The car made 510 rwhp & 518 tq @ 6 lbs of boost with the injectors at 78% duty cycle. What else could I do to make some more boost/hp?
Do you recommend going with the 3" or 2.75" pulley, and if so what other mods would I need. My goal is to make 600rwhp.
Thanks!
Old Apr 21, 2014 | 12:36 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
A smaller pulley would obviously increase boost, but you will need to check your injectors and fuel system to make sure the extra power is supported. If my memory is right each step down in pulley size is about 1.5 lbs of boost.
Old Apr 21, 2014 | 12:40 PM
breecher_7's Avatar
breecher_7
This brightened my monday....
Old Apr 21, 2014 | 12:43 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I bet it did. You have a "PD blower thread alert" or something. LOL
Old Apr 21, 2014 | 01:42 PM
breecher_7's Avatar
breecher_7
Something like that.....
Old Apr 21, 2014 | 01:45 PM
breecher_7's Avatar
breecher_7
Thanks!
Find out what Max RPM for that blower is, do the math, get the pulley that will take it to max RPM @ 7000rpm. Get a set of Bosch 1000cc injectors and a Alky control kit and let it eat.....
Thats my $.02
Old Apr 21, 2014 | 02:33 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Thats my $.02
Max for an eforce is 20000 rpm. Mine turns 19700 at 6800 rpm with a 2.75 inch pulley and an 8% OD ATI damper. Its pretty maxed out there but can make enough power.
Old Apr 21, 2014 | 02:41 PM
breecher_7's Avatar
breecher_7
Old Apr 21, 2014 | 02:44 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Your the best ! Just because your PD didn't work out doesn't mean they all don't. You didn't try hard enough. I am more than happy with 780 RWHP and I don't have any serious heat problems.
Old Apr 21, 2014 | 02:47 PM
breecher_7's Avatar
breecher_7
Im gonna have a stroke just thinking about screw blowers...
Anyways, OP... Thats about the best recipe you can run with...
2.75 pulley, 8" O.D. Balancer, 1000cc Injectors ( you wont even get close to running these out of fuel! ) and a meth kit...
Old Apr 21, 2014 | 02:54 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Op... breecher has experience, and for once I agree with his advice. I have 850cc injectors and they are less than 60% duty cycle so 850's or 1000's will be more than enough.
Breecher, don't have a stroke. Us PD guys would miss you terribly.
Old Apr 21, 2014 | 02:58 PM
breecher_7's Avatar
breecher_7
Yeah 850's are plenty big. But why not get 1000's? Price isnt much different. Plus that way when we wises up and sees the light, tosses that heat pump in the trash can and bolts on a centri or turbo system he will have enough fuel for 1000whp..
Old Apr 21, 2014 | 03:02 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I take back what I said. Go ahead and have a stroke.
Old Apr 21, 2014 | 03:08 PM
NASTY VETTE
Would you recommend a TQ converted as well? 2600 or 2800?
breecher_7's Avatar
breecher_7
Thanks Buddy!
Hey, look on the bright side! It would be one less car on the street and track outrunning you!
You are making my monday, I truly enjoy this endless banter.
Old Apr 21, 2014 | 03:09 PM
breecher_7's Avatar
breecher_7
2800 would rip pretty good. I personally would go a little higher, but it really depends on what your doing with the car.
Old Apr 21, 2014 | 03:13 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Thanks Buddy!
I do too. Keeps me occupied when the markets are slow.
To E force sc needs more boost/hp! Help!
Old Apr 21, 2014 | 03:15 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
The stall should be matched to your setup and torque curve. I have a 2600 now but I can tell you at 600 rwhp it worked pretty well with the stock stall.
My car remains after 2 years the fastest LS2 power adder car with an A6 on the list, and that was with a stock stall and cam. Not sure how far down the centri cars are n that list.
Old Apr 21, 2014 | 03:22 PM
breecher_7's Avatar
breecher_7
Old Apr 21, 2014 | 03:45 PM
NASTY VETTE
Very nice! Thank you guys for all the help.
