C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost + Nitrous or Boost only
Old Apr 23, 2014 | 09:47 AM
jon6.0's Avatar
jon6.0
Default Boost + Nitrous or Boost only
All the parts are in for my motor build. So now I have to decide if I'm going to add a shot of nitrous on top of the Ti trim blower on my stock cube forged LS3. I'm leaning toward yes. My question is how much more blow by will the motor have gapping the rings a few thousandths bigger? Currently I just have each valve cover vented with a small filter on each cover and a Elite Engineering catch can.
Old Apr 23, 2014 | 10:07 AM
Slo-Poc's Avatar
Slo-Poc
You know my answer its a kick every time.
Old Apr 23, 2014 | 10:40 AM
jon6.0's Avatar
jon6.0
Are you using a plate or just a single nozzle? How much are you using?
Old Apr 23, 2014 | 10:48 AM
Detoxx03's Avatar
Detoxx03
He's using a nozzle since a plate won't fit. Was 100 before the build but depending on what his makes after installing the 8 rib kit that's when they'll decide on how much to spray. I say 150 but I'm a nitrous veteran.
Only way I would do it on this car is if I go direct port other than that I'm not really interested
Old Apr 23, 2014 | 10:53 AM
Unreal's Avatar
Unreal
Should be able to make 800-850rwhp easy enough with the blower. Going to start investing in rear end? Spindles? Etc? If you are, then add the n2o. If you don't plan on doing any of that then I would just go blower only because you will be traction limited anyways.
Old Apr 23, 2014 | 11:24 AM
jon6.0's Avatar
jon6.0
I want to start doing the 1/2 mile and 1 mile events. Was thinking of doing a 16" rear wheel with a 295/50-16 Hoosier drag radial. Those should fit over my base rear brakes and give me plenty of traction. Then I just need to upgrade the diff.
Old Apr 23, 2014 | 11:49 AM
Unreal's Avatar
Unreal
Then do the n2o.
Finding 16" wheels that fit is the hard part. Custom bogarts are the only 16 I've seen that fit.
Old Apr 23, 2014 | 11:51 AM
jon6.0's Avatar
jon6.0
Originally Posted by Unreal
Then do the n2o.
CCW's fit. I tried Andy's 16" C5 CCW's on my C6. The offset was off a bit, but they cleared everything.
Old Apr 23, 2014 | 11:53 AM
corvette8189's Avatar
corvette8189
I can get u a NX kit at a great price just pm me
Old Apr 23, 2014 | 12:11 PM
Unreal's Avatar
Unreal
Yah but CCW stopped making a lot of wheels so unless you find a used set. They don't make classics anymore.
Old Apr 23, 2014 | 12:52 PM
jon6.0's Avatar
jon6.0
Those. Dirty. Bastages.
To Boost + Nitrous or Boost only
