C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
fuel line. on e-force
Old Apr 27, 2014 | 08:56 AM
mejetdrvr's Avatar
mejetdrvr
Default fuel line. on e-force
hey e-force guys. anybody have an good picture or more. of the install of the e-force fuel line, the one at the end of the drivers side fuel rail. fire wall end. yes the one that has the 180 degree turn. I'm not liking the way mine is resting or the position of mine. to me, it puts the fuel line on top of the coil pack wiring. I'm afraid its gonna rub, chaffe the wiring. so, if some one would post a pic. so I can see if I messed up, or I need to reposition the fuel fitting....thanks
Old Apr 27, 2014 | 10:48 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I don't remember having any issue like that with the stock setup. I later redid the fuel line to feed both rails from the back because I feel its safer and a more even way to feed all the cylinders.
Old Apr 27, 2014 | 11:19 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
I had to adjust/move the support clamp (on the firewall) a little while installing the EForce to gain the needed clearance on my Dad's 05. It just took a little massaging and bending.
Old Apr 28, 2014 | 05:21 PM
mejetdrvr's Avatar
mejetdrvr
realcanuk, that's an interesting fuel set up. if I may, why do you feel its an safer set up?
joeyg, thanks for the tip. I will end up going back in there and doing some changing, to gain some room. before the grimlin's show up...
Old Apr 28, 2014 | 05:24 PM
mejetdrvr's Avatar
mejetdrvr
realcanuk, questions for ya. what did you do with your e-force sct scanner? can it be used for anything besides pulling codes? once I get her tuned, can I copy from car that tune? or will that mess up the edlebrock tune? thanks
Old Apr 28, 2014 | 05:37 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
As far as the fuel line, I just didn't like that one cylinder gets fed last. I don't think its really an issue unless you are pushing bigger power which needs more fuel.
I never had the sct scanner. It was custom tuned from the start with HPT.
Old Apr 28, 2014 | 06:43 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
I don't know if these will help. If your interested in a fuel line upgrade, Jannetty Racing sells them. I bought one, just haven't installed it yet.
http://www.jreperformanceparts.com/j...-corvette.html
Old Apr 28, 2014 | 07:22 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I know Jannety sells these to the Camaro guys. Really no big deal to put it together.
To fuel line. on e-force
