C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
need info nitrous ls7
Old Apr 29, 2014 | 07:23 AM
10gt5's Avatar
10gt5
Default need info nitrous ls7
I have a stock bottom end with a big cam, milled and ported heads, br7 plugs, full exhaust, car should make ~600rwhp na.... I am starring at my nitrous express 90mm plate kit with all the goodies, will it be safe for 100 shot from time to time?
Old Apr 29, 2014 | 09:32 AM
corvette8189's Avatar
corvette8189
Just make sure u have good gas and a tune and you'll be fine
Old Apr 29, 2014 | 09:41 AM
10gt5's Avatar
10gt5
It's Florida we have 93, but that's all I want to run, no race gas for me
Old Apr 29, 2014 | 09:54 AM
Slo-Poc's Avatar
Slo-Poc
They have dedicated fuel cells that work well for added octane for safety.
Old Apr 29, 2014 | 09:56 AM
10gt5's Avatar
10gt5
I've seen that I just don't want to run anything I want to stay straight 93
Old Apr 29, 2014 | 10:26 AM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
you can run 125 with safe tune not sure about the 150, a friend 07 Z still on the stock short block spraying the 125 and everything is good " 98 oct "
Old Apr 29, 2014 | 10:36 AM
10gt5's Avatar
10gt5
I'm only looking to do 100 but I have to stay on 93 octane
Old Apr 29, 2014 | 11:07 AM
EX1's Avatar
EX1
I would recommend some better fuel just to be safe. Splash a couple gallons of VP in your tank if you are going to go out racing. If you don't do that I would run a hell of a safe tune and take some timing out. I run 13.8 compression with LS7 heads milled .130 and a 125 shot. Car made 749whp 760wtq but I am also on E85.
Do a flex fuel setup with sensor and fill up with E85 at the pump if you want to go spray. There are a handful of members here doing it. Looks like you have some E stations in Florida, any near you?
Old Apr 29, 2014 | 11:28 AM
ProEFI's Avatar
ProEFI
So using E85 or C16 as you like for races and keep the car on 93 oct while you're cruising.
Best,
Mubarak.
Old Apr 29, 2014 | 11:59 AM
10gt5's Avatar
10gt5
I don't have anything near me it's a extremely far drive, at this point if it's gonna be impossible to run a 100 shot on pump gas I might just send it all back and get my money back, I don't wanna blow the car up but I really wanna spray the car on pump gas
Old Apr 29, 2014 | 12:02 PM
EX1's Avatar
EX1
Well I don't prefer this stuff but if you aren't going to spray real often you could pick up some bottles of Torco and dump it in the tank when you plan on spraying.It will give you a little safety margin. Just be sure to mix it in a gas can first to help dilute it.
Old Apr 29, 2014 | 12:26 PM
10gt5's Avatar
10gt5
I don't wanna tune with torco, could I add it after its tuned just to bump octane?
Old Apr 29, 2014 | 01:52 PM
EX1's Avatar
EX1
It isn't the best practice but yes you can.
Old Apr 29, 2014 | 02:16 PM
10gt5's Avatar
10gt5
I'm only gonna spray it once in awhile idk yet but I spent 1000+ on nitrous stuff and I don't wanna return it
Old Apr 29, 2014 | 02:32 PM
LS7 BUD's Avatar
LS7 BUD
If you wanna run a 100 shot without race gas then put in forged pistons or kiss that bottom end goodbye... Had a buddy do the same thing and it popped on 93 octane... One hot day and it went boom...
Old Apr 29, 2014 | 02:50 PM
ProEFI's Avatar
ProEFI
since you wanna spray at the safe side then you have to get a gallons for your ride even if it's far away fill two gallons and keep them home for anytime you wanna spray it that's the only way you can enjoy the nitrous otherwise kiss your LS7 the goodbye kiss that's it
Old Apr 29, 2014 | 03:09 PM
EX1's Avatar
EX1
Pump gas is only going to get you so far when your hp starts to get up there. If you want more, you are going to need to run the correct fuel. If not, you will be tinkering with a very expensive and dangerous situation.
-Flex fuel setup with a new tune and use E85 when you spray
-Buy a 5 gallon pale of VP fuel and mix in a few gallons when you run. Doesn't need to be C16 or anything crazy. I used to use the 112 mix.
-Use Torco with your pump fuel (dirtest solution)
-Look into meth kits for your added safety.
To need info nitrous ls7
Old Apr 29, 2014 | 05:05 PM
Pb82 Ronin's Avatar
Pb82 Ronin
Can run a 150 shot with an interceptor, 93 octane pump gas, and a stock engine all day long. Asking me how I know. Stock bottom end is fine to 700 rwhp. Spray it and quiet the naysayers.
Old Apr 29, 2014 | 05:09 PM
ProEFI's Avatar
ProEFI
himmm is that meaning If I was a stock Z I can spray 200 on stock end?
Old Apr 29, 2014 | 08:28 PM
10gt5's Avatar
10gt5
Well I'm a sissy I guess I'm going to return it all and enjoy a strong hc car
