C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Fuel pressure fluctuation
Old May 13, 2014 | 11:05 PM
Clover0925's Avatar
Clover0925
Default Fuel pressure fluctuation
Just put together my combo, stock ls2 with pat g cam, t trim, and 60 lb injectors. Not sure if it's my sending unit for the gauge or something in the tune I have. What should my pressure be? Stock pump also with a BAP.
I recall when I fired it with the stock injectors and tune it had about 50. I had to obviously crack the line to change the injectors, then downloaded my new start up tune given for the 60's. I bled the air out of it also.
Old May 14, 2014 | 10:30 AM
Streetk14's Avatar
Streetk14
Nothing should have changed in regard to fuel pressure at idle. The pressure is mechanically regulated, but I don't think all cars are exactly the same. I think the "normal" spec is 58 psi. My old car seemed to run at 60 or above most of the time, at least according to the gauge I installed.
There's no bleeding or anything else that needs to be done after opening these fuel systems. It'll fill and bleed out any air when you fire up the engine. If you're worried about the pressure, maybe verify it with a high quality mechanical test gauge (ie Snap On, etc).
Old May 14, 2014 | 01:38 PM
Clover0925's Avatar
Clover0925
Will do tonight. I have also in the meantime done some more research, guess possibly this is a common issue with Glowshift gauges?
Old May 21, 2014 | 09:49 PM
Clover0925's Avatar
Clover0925
Well, it has to be the sending unit. I put a manual gauge on it and it's 60lbs. I will call glowshift tomorrow
Old May 23, 2014 | 08:52 PM
Clover0925's Avatar
Clover0925
Glowshift is sending me 2 units on my dime. They suck!
To Fuel pressure fluctuation
