C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Burn out= Reduced Engine Power?!?
Old May 18, 2014 | 07:44 PM
ATLS2's Avatar
ATLS2
Default Burn out= Reduced Engine Power?!?
so I went to the track today since Sep 12. it's an eighth mile track up here in North Dakota, and last time I ran it 8.7. Well I go there after getting the supercharger and and transmission work, and I run a 8.1 on my first try. That's not the part that is tough, since I didn't do a burnout on the first pass I attempted one on this second pass. so I turn off the traction control and the stability and do a burnout, but that's when I get a check engine light and a thing saying reduced engine power. Has anybody had this issue before?
Old May 21, 2014 | 04:25 AM
Dynomax's Avatar
Dynomax
8th Gear
I'll be very interested in the answer to this. I fitted a set of Michelin PS2 ZP's today to our stock 2011 GS. I wanted to see how they reacted leaving the line. Found some quiet dry asphalt, turned off the traction and stability control, nailed it with quite an amount of wheel spin (all good) and then noticed the check engine light on. I did not get the message saying reduced engine power and everything else checks out ok. Any ideas?
Old May 21, 2014 | 05:08 AM
ravill's Avatar
ravill
Time to hook up an OBD II scanner.
When you start messing with these engines, it's time to get one.
Old May 21, 2014 | 09:16 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Possibly just tuning parameters not set high enough, or a worn out throttle body equating to a throttle correlation problem. Like Ravill said, time for a scanner.
Old May 21, 2014 | 09:39 AM
ATLS2's Avatar
ATLS2
Whats a cheap reliable obdii scanner?
Old May 21, 2014 | 01:49 PM
boostaholic786's Avatar
boostaholic786
you can get an OBDII scanner at autozone for about $40 bucks if I'm not mistaken???? I know its not more than that for sure because I got the pocket scanner with more features such as advanced diagnostics ect (like abs, airbags lights) and mine was $69.99....not that big of an expense when you need to know whats wrong with your car
Old May 21, 2014 | 04:46 PM
ProChargerTech's Avatar
0ProChargerTech
Former Vendor
Bets could be placed on if its the MAP/MAF correlation error...vs others.
To Burn out= Reduced Engine Power?!?
