C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
441 Stroker v3 Procharger
Old May 30, 2014 | 11:56 PM
eagmail's Avatar
eagmail
Default 441 Stroker v3 Procharger
Almost finished car should be running soon what numbers should i expect?
Motor is a 441stroker low compression top to bottom.
Ill get build sheet soon but off top of my head
Stock Heads with all upgraded hardware of course and ported.
dragonslayer crank
crower valvetrain/full rockers
crower 800hp rated rods( called them they have yet to seem someone break them )
low comp pistons
aeromotive fuel system blahblah
What #'s should i expect engine builder told me 700 would be safe on pump gas due to detonation 700 is low and dissapointing seeing some guys pushing 650-800 on stock motors all day.
What do you guys think? i was hoping for 700 low boost and 900wrhp high boost hoping torque doesnt go over 800tq due to rods only rated for 800 even though i called crower and they said theyre unbreakable
Old May 31, 2014 | 10:15 AM
1MEANGS's Avatar
1MEANGS
What block?
Old May 31, 2014 | 02:48 PM
lt1z's Avatar
lt1z
The main problem I see is that you built a large low compression motor with a small blower, assuming either a V3 Si or V3 T trim. You would have been better off with either higher compression or a larger blower. Detonation should not be an issue if you have a good tuner. The smaller V3 blower just can't move enough air to make good power on a large low compression motor like that.
I run a V3 Ti but on a relatively high compression 377 and that combo works well.
Then again you also said pro charger so if you have a D1 or larger and not a V3 it may work out OK.
Old May 31, 2014 | 05:30 PM
Eddynonya's Avatar
Eddynonya
I'd have to see the compression I think it was 10 something.
Builder said not to run more than 700hp on pump gas so no detonation
So if I where to get a bigger procharger I would easily make more power at same boost what concerns me is never had 700hp car at most 650 builder concerned me when he said that I'm quessing I can reach 800hp on high boost whih is my prochargers max and run meth or can I do 750-800 on pump gas ?
Old May 31, 2014 | 05:45 PM
Presence Dist.'s Avatar
0Presence Dist.
Former Vendor
sounds like you shouldnt be having that guy build your motor if he suggest that. There are tons of cars making over 700rwhp on pump gas.
You also still have said what supercharger you actually have. V3 is a vortech and porcharger is a procharger with multiple series in between. You need to be more specific. Along with trans also. Where are you located at? do you have a good tuner?
Old May 31, 2014 | 05:55 PM
Eddynonya's Avatar
Eddynonya
V3 si
Stock trans but new
In Miami fl and yeah tuner is
Gtg
Old May 31, 2014 | 06:52 PM
qwiketz's Avatar
qwiketz
Way too small of a blower with 441 cu inches
Old May 31, 2014 | 07:33 PM
Detoxx03's Avatar
Detoxx03
Yeah you need to go somewhere else to get your work done or go ahead and get a bigger blower from the get go.
Old May 31, 2014 | 08:07 PM
lt1z's Avatar
lt1z
As mentioned above you are going to need a bigger blower. The Si will make over 700 on an 11:1 compression LS7 but not a low compression 441. Go get a YSi for it which will fit your V3 bracket.
Old May 31, 2014 | 10:33 PM
Unreal's Avatar
Unreal
Just sounds like a bad setup. Next time ask advice before putting a combo that isn't that good together and save the hassle.
441 may not like boost. No reason to run a "800hp" rod when there are plenty of 1000+rwhp rods with no issues. Stroker isn't going to like big power if it is an ls7 based stroker I wouldn't even try to boost it. The thin ring land won't like big boost. Hell they are hard enough to get going well n/a let alone with a bunch of boost.
Old May 31, 2014 | 10:43 PM
Eddynonya's Avatar
Eddynonya
Let's see how the #s are and how it turns out!
Hopefully I'm not completely disappointed I believe the comp is 10:9
Old May 31, 2014 | 10:53 PM
Unreal's Avatar
Unreal
Probably make ~650-700, but so did my stock ls7 and many others with nothing but a v3-si kit/headers.
Old Jun 1, 2014 | 12:25 PM
Streetk14's Avatar
Streetk14
Wow... that really doesn't sound like a very good combo. Not trying to hurt any feelings. Maybe some things are being lost in translation? Hopefully that's the case.
You said low compression, then 10.9:1 -- but those are two different things. Is this an LS7 build? What kind of stock heads are on it? I really hope it doesn't have stock LS2 heads on it.
Old Jun 1, 2014 | 11:58 PM
ANGRY Z's Avatar
ANGRY Z
Wicked
Old Jun 2, 2014 | 09:03 AM
Impulse20098's Avatar
Impulse20098
Subscribed. To see where the hell this thread may take me.
Old Jun 2, 2014 | 09:17 AM
1MEANGS's Avatar
1MEANGS
Be careful might take ya to the moon and back LOL
Old Jun 2, 2014 | 11:03 AM
0Presence Dist.
Former Vendor
With that much CI,the right heads,and big blower and the right supporting mods car would be a monster for sure. Just have to piece together the right recipe
To 441 Stroker v3 Procharger
Old Jun 2, 2014 | 11:40 PM
Eddynonya's Avatar
Eddynonya
I'm looking for an f1 let's see how much power if I can make 800 -750 on a v3 I'll be happy. Until I get an itch to go higher
Old Jun 3, 2014 | 09:35 AM
Unreal's Avatar
Unreal
v3 won't support 750-800rwhp. If you are talking crank numbers then that shouldn't be an issue.
Old Jun 3, 2014 | 10:01 AM
lt1z's Avatar
lt1z
A T trim can make to 800 on certain combos, Ti a little higher but 750 is about the cap for an Si
