C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
F1X build
Old Jun 4, 2014 | 09:42 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Default F1X build
well it is finally time to start the actual build of the new project.. I'm looking for all known options as to the fuel system. I am aware that the entire system will need to be upgraded. I am also installing the E85 sensor kit from Steck. Here are the details and I appreciate any fuel system opinions:
06 Z06 will run on E85
F1X procharger with air to air intercooler
LS3 block with LS7 Darton sleeves
Callies dragonslayer crank 427 CI
oliver rods
wiseco pistons 10:1(because E85)
RHS ls7 heads with Ti/inconel valves
comp cams custom grind cam in the 265/ .675 range
short travel lifters
shaft rockers
RPM transmissions A4 conversion
American Racing Headers 2" headers
Yank custom converter
stock diff(3.42)
15" 275/60 rears
So what are my options for fuel system and injectors?
I'm ready to order right now as I am going to pull the tanks this weekend.
The plan is to run 8.4s with the car and retain a great amount of drivability. I think it will take about 1000whp but this combo will be capable of much more. But.... because I am running E85 the system has to handle the additional fuel needed for the E85. No matter what I will not stop digging until I surpass the 8.50 mark. Any help is appreciated
Old Jun 4, 2014 | 10:03 PM
yur2slo's Avatar
yur2slo
Pretty similar to my build now, except I'm using Mast heads and ERL 6-bolt block and manual tranny. Are you going with a 6-bolt setup? I'm not running E85 but went with a huge Magnafuel pump (MP-4703) to kick on under boost, with the stock Z06 pump in tank. I'm running the ID2000 injectors which would probably work for your build as well.
Old Jun 4, 2014 | 10:08 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
the rhs heads have a thicker deck and I'm running head studs(4bolt) I think I can get where I need to be on 18-20 psi(I hope lol)
Old Jun 4, 2014 | 11:43 PM
c5austin's Avatar
c5austin
Sounds like a wicked build!!!! Out of curiosity what bracket are you going to run? Pulley size to get that 20 lbs?
Old Jun 4, 2014 | 11:59 PM
Unreal's Avatar
Unreal
4l80 or 65? I assume 80 since f1x.
Old Jun 5, 2014 | 12:08 AM
Presence Dist.'s Avatar
0Presence Dist.
Former Vendor
I can set you up with a nice Fore setup. Which works great and hold while making great power. Car is going to be a monster for sure!!!
Also i would do id2000s or FIC 2200. Have had customers have great luck with both.
Old Jun 5, 2014 | 12:55 AM
ajrothm's Avatar
ajrothm
Sounds like a killer build!!
The only thing on your list that I question is the Ti valves.... Ti valves and boost is normally a NO NO... The TI can not handle the heat... I would stick with hollow stem intake valves/inconel exhaust valves..
I'm also curious about the trans? PG or 4l80?
I can't wait to see how it all comes out.
Old Jun 5, 2014 | 08:06 AM
White_Lightning's Avatar
White_Lightning
what crank/blower pully combo do you plan to run?
Old Jun 5, 2014 | 08:25 AM
stanger383's Avatar
stanger383
St. Jude Donor '09
I don't have the pulleys yet... I ordered my blower over 6 weeks ago and it will be at least another 2-3 weeks they said.
we are going with a 4l60 for this build. I think Rodney might have a few tricks up his sleeve.
as far as the boost I will run that will be based on track performance. If I can go 8.40s on 900whp (probably not likely) then that's where I will be.. if it takes 1100 at the tire then that is where I will be. I know the Trans will be at its limit or beyond but that is what we are doing and it might be a test bed for more upgraded 4l60 parts for RPM transmissions to develop
Old Jun 5, 2014 | 06:56 PM
TT32VGT's Avatar
TT32VGT
nice upgrades!!!
Old Jun 6, 2014 | 10:15 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
What bracket system Norm? Procharger?
Old Jun 6, 2014 | 10:59 AM
chriswood's Avatar
chriswood
I would keep it simple and accessible, do a walbro 450 e85 pump in the factory fuel canister for your primary pump.Then put a bulkhead in the factory tank and run a magnafuel 4303 off a hobbs to a y into the same feed line. I just did this setup and am really happy with how it turned out, not only is it very simple and accessible but it doesnt cost a fortune like alot of the in tank or inline setups offered. This is the in tank pump i used http://www.foreinnovations.com/produ...-f90000267.htm and this is external pump http://www.summitracing.com/parts/mrf-mp-4303.
Old Jun 6, 2014 | 12:05 PM
DSteck's Avatar
DSteck
You should call me to discuss again.
Old Jun 6, 2014 | 12:20 PM
silvzo6's Avatar
silvzo6
thats what i did
Old Jun 6, 2014 | 12:31 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
procharger. head unit bracket and Dallas performance direct drive for accessories
Old Jun 6, 2014 | 01:30 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
will do
Old Jun 8, 2014 | 07:15 PM
z0vette's Avatar
z0vette
How much HP will this setup support? Looks like an easy fuel system that costs nothing compared to the other setups.
Do you have a drawing/sketch to be used as a guideline?
To F1X build
Old Jun 8, 2014 | 07:28 PM
Blackonblacksls's Avatar
Blackonblacksls
Would need to drop tank and install block offs to make it truly boost referenced.
Then add a regulator and filer..
It adds up like they all do.
But does seem to be one of the quicker easier ways to do things.
And you wouldn't really need I change the in tank pump since you have a z06
Old Jun 8, 2014 | 09:59 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
They believe a 5" with the 8" crank pulley will net about 14 psi.. That is where I will start and then pulley up from there
Old Jun 8, 2014 | 10:32 PM
jon6.0's Avatar
jon6.0
I thought people were having issues running the ID2000's with E85?
