C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boost A Pump ?
Old Jul 8, 2014 | 03:06 PM
TripleAstyle123's Avatar
TripleAstyle123
Default Boost A Pump ?
How many are using a Kenne Bell “Boost A Pump” ? I am considering adding SC and am only worried about this item. 2008 LS3. Are these boost a pumps as reliable as just replacing the stock pump? Or is it just a cheap alternative with no inherent risks? THANKS
Old Jul 8, 2014 | 03:31 PM
Pitufina's Avatar
Pitufina
I've never heard about reliability issues with the KB BAP, but yes on the old MSD models. Most people use the BAPs up until about 650-700rwhp with meth and at that point add an ECS or A&A Stg 1 fuel pump addition from what I've read.
Old Jul 8, 2014 | 04:24 PM
Streetk14's Avatar
Streetk14
I've had good luck with the Kenne Bell BAPs. The key to reliability IMO is a solid install.
Pick up a harness from Racetronix so you don't have to cut any factory wiring. Then crimp + solder + insulate all connections. Done.
A Z06 pump is another option for a mild setup. It's just a lot more labor intensive to install, and I don't think it'll support as much power by itself vs a BAP with a stock pump.
Old Jul 8, 2014 | 04:43 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
http://www.eastcoastsupercharging.co...mart&Itemid=29
Old Jul 8, 2014 | 05:17 PM
Sof_Top's Avatar
Sof_Top
Does that vortech fpb have the same output as the KB bap?
Old Jul 8, 2014 | 09:45 PM
croatbob's Avatar
croatbob
I ran a kb bap on the stock z06 pump at 755whp. No issues
Old Jul 9, 2014 | 08:54 AM
scottg's Avatar
scottg
Just had one put on my 2008 ls3. It was starving for gas at 6100 rpms with smaller pulley on heartbeat supercharger. DRM put on the Kenny Bell bap. 3 weeks ago. Got to open it up last week-end. Went fine all the way up to red line No problems. But had to dyno it to make sure it was right and getting enough fuel in higher rpms. At the time of install. You are less than 3 or 4 miles from me. DRM is in Waverly MN About 50 miles one way. " 559 rwhp". Before I was making 514 rwhp before pulling down and stock pump was fine.
Old Jul 9, 2014 | 03:39 PM
ZAKO6's Avatar
ZAKO6
I had this same question when I went SC.
I have never read anything about reliability issues and a BAP should take you to 600+.
FWIW i just installed a FP gauge on my car. At idle its 59/60 and WOT through all gears that thing is glued at 55 psi. So i think its doin its job. I made 550 whp on a mustang dyno.
Old Jul 9, 2014 | 09:09 PM
ProEFI's Avatar
ProEFI
Supremacy 1 car at a time
I had the KB BAP on my Z and it's will go as soon as I get my new fuel system and it's a good choice of 700+Meth not more.
Old Jul 10, 2014 | 07:28 AM
EuroRod's Avatar
EuroRod
All the KB BAP does is increase the voltage to the stock fuel pump under boost conditions. My tuner said that the stock system is sufficient up to 600rwhp, and the BAP will shorten the life of the stock pump.
My car makes 550 rwhp, and I've been running the stock pump with the ProCharger for 55k miles and 7 years with zero issues.
I do use the RaceTronics fuel pump wiring harness that puts voltage directly off the back of the alternator to the stock pump, which reduces the possibility of voltage drop during high usage occasions.
Old Jul 10, 2014 | 01:08 PM
scottg's Avatar
scottg
Just be careful. Had the Heartbeat put on last year. 514rwhp stock pump was just fine plenty of gas getting to the motor. Went down to the 084 pulley last three digits on pulley from magnuson. and at 6100 rpms it was not getting enough gas at 559rwhp and 539 rwt. He then suggested the kenny bell pump only goes on at 3lbs of boost and up. Took three weeks to get it in for the pump. Drove it like a granny for 3 weeks. Tunner said starving for gas can hurt or wreck your engine. Mine is 2008 ls3 12,000 miles on it. 2,000 on supercharger
Old Jul 10, 2014 | 03:34 PM
grocerygetter's Avatar
grocerygetter
question...the harness you guys are suggesting to use with the ECS bap is: FPNH-008 and PBIC-001?
Old Jul 10, 2014 | 04:10 PM
ZAKO6's Avatar
ZAKO6
Yes...that harness. Thats a good idea too. And make sure to get the little in-line connector so you can do the ends of the BAP wires nice and not have to cut/solder wiring.
This one...... Pump boost interface blah blah
http://www.racetronix.biz/itemdesc.a...PBIC%2D001&Tp=
Old Jul 10, 2014 | 07:03 PM
2019 ZR1's Avatar
2019 ZR1
I had one put in one time that was done half a$$ and the wires weren't put together very good. It blew 2 fuses and left me stranded twice. My suggestion is to make sure you take your time and do it right.
Old Jul 10, 2014 | 09:29 PM
Streetk14's Avatar
Streetk14
Yep. Like I said up above: Crimp, then solder, then seal all connections. On my new build, I even went as far as to get a different Hobbs switch that uses an OEM style weatherpack connector.
Old Jul 11, 2014 | 05:44 PM
Still_Slow's Avatar
Still_Slow
which Hobbs switch is it, do you have a part number, that's sounds like a good idea for just in case!!
Old Jul 11, 2014 | 10:36 PM
Streetk14's Avatar
Streetk14
Lemme see if I can find that info. It's also adjustable, which is really nice.
Old Jul 11, 2014 | 10:50 PM
Streetk14's Avatar
Streetk14
Here you go: http://www.racetronix.biz/itemdesc.a...PS%2D2&eq=&Tp=
They make versions with other pressure ratings too. I went with the 2 psi version and was able to set it to activate at 3 psi. I didn't notice this before, but that schematic in the link I gave you lists the different springs and adjustment ranges. Looks like mine is 1.1-3.0 in.hg, and the next one up is 4-8 in.hg.
You'll also want the connector kit: http://www.racetronix.biz/itemdesc.asp?ic=RCS%2D007&Tp=
Old Jul 11, 2014 | 11:00 PM
Still_Slow's Avatar
Still_Slow
Streetk14 FTW!!
Frankie
To Boost A Pump ?
