C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dashlogic reading boost?
Old Jul 13, 2014 | 09:35 AM
Quick2's Avatar
Quick2
Default Dashlogic reading boost?
Is it something additional that needs to be hooked up to Dashlogic to read boost? Thanks
Old Jul 13, 2014 | 10:11 AM
Pitufina's Avatar
Pitufina
A zr1 map sensor, part number 12592525. Also tuner needs to know the conversion to use in the tune for proper function and boost reading.
And there's a formula and pid in the dashlogic that needs to be set as well IIRC.
Old Jul 13, 2014 | 10:48 AM
Unreal's Avatar
Unreal
Zr1 map sensor is one way. Any map sensor that can read boost. I use a DTE 2.5 bar sensor. Zr1 sensor is only plug and play for certain years so you may need a different one. If you don't want to mess with the tune then get any map sensor and just wire it to the dashlogic and setup the PID.
Old Jul 13, 2014 | 01:41 PM
Streetk14's Avatar
Streetk14
At this point, I think this needs to be a sticky
For an LS3 car the LS9/ZR1 MAP sensor is the way to go. It's plug & play. Just need to change the calibration values in your tune file.
For LS2 or LS7 cars, I don't think it's a direct fit. May need to modify the manifold and/or get a wiring adaptor.
Like Unreal said, you can also run a standalone MAP sensor and plug it directly into the DashLogic's 0-5 volt inputs. To me, that's more work and more complication, though. The LS9 MAP sensor is a much better solution.
Old Jul 13, 2014 | 04:21 PM
Unreal's Avatar
Unreal
DPE or DSX offer plug and play maps for ls7/ls2 if you wanted to do that.
If you don't have access to HP tuners or the tuner wants to charge to swap those values then the standalone is easy IMO. Not as easy and just plugging in a DSX or LS9 sensor but I rather spend 30 minutes wiring a map sensor to the dash logic than pay $100+ to have someone adjust the tune if that is what it took to get the other options working.
Old Jul 14, 2014 | 10:41 PM
Quick2's Avatar
Quick2
Thanks, guys. I'll probably just keep reading my mechanical gauge.
Old Jul 14, 2014 | 11:41 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I'm not getting something here. If the car is boosted, wouldn't you already need at least a 2 bar map sensor to tune it properly? Then wouldn't the gauge read off that? I know my aero force gauge reads fine from the obd running the map sensor that came with the eforce.
Old Jul 15, 2014 | 10:20 AM
Streetk14's Avatar
Streetk14
I think "properly" is the key word here. None of the centri blower kits and most of the PDs don't include a new MAP sensor, though. I think the E-Force is the only one.
I changed mine on both my C6 FI builds because 1) I wanted to be able to log boost, and 2) I wanted my effective injector flow rates to be accurate when in boost.
I don't think it makes a major difference to WOT fueling, but I like my stuff to be as accurate and consistent as possible.
Old Jul 15, 2014 | 10:21 AM
Unreal's Avatar
Unreal
No. Most boosted c6s are just using the maf. If it was a speed density tune then yes, you would need a map sensor that is accurate but if you are just using maf for boost then no need.
Old Jul 15, 2014 | 10:26 AM
Streetk14's Avatar
Streetk14
The injector flow rates aren't right if the MAP is pegged. Might not be a major thing to tune around, but is worth doing in my opinion.
Old Jul 15, 2014 | 10:27 AM
Unreal's Avatar
Unreal
Agreed, I wouldn't do it otherwise and I've always had a map to read boost as I want it accurate but many just tune around it. Hell, most of the tunes I see don't even have the correct injector data in them, let alone worry about something like this. Just adjust the PE map until WOT is good and call it a day.
Old Jul 15, 2014 | 10:29 AM
Streetk14's Avatar
Streetk14
Sad but true
To Dashlogic reading boost?
