I just bought a new LS2 block from a forum member and will soon start building a stock displacement LS2 short block that will be supercharged. Sticking with off the shelf pistons, I have some choices to make regarding compression ratios. Using Wiseco's as an example; I can stick with a flat top that will give me 10.6:1, or I can select an 11cc dish that would put me at 9.7:1.
The 10.6:1 choice would likely be more responsive, with snappier throttle response, but with 91 pump gas, boost levels would be limited. I'd like to leave meth out of the equation for now. Alternatively, I could select the 9.7:1 dished piston, and likely lose some throttle response, but would be able to run more boost and/or timing. Again, leaving meth out of the equation.
If you were starting from scratch, which direction would you go - less static compression and more boost? Or, more static compression and less boost?
I think mine would be more compression less boost. Personally I prefer an engine that feels torquier/responsive off boost while cruising and crack the whip when needed.
Unless your build is a "***** out....scratch and claw for every last hp, competition motor", and you have the blower to support the extra air flow, I'd shoot for the higher compression ratio. There's a jillion stock short block LS2's, 3's, and even 7's living large in the 650 to 700 rwhp range. That's with crap pistons. Yours will be forged. I've had lower compression supercharged motors before. Never again.
Dynamic compression ratio (camshaft choice along with static ratio) has a say in how all this plays out too. That and timing dictate cylinder pressure. Available octane dictates how much cylinder pressure you can deal with. Lots of variables to consider. If you don't mind being a little more sluggish out of boost and the fuel eco penalties, the lower comp ratio might be for you. I won't do it. Been there, done that, have the t-shirt....won't wear it
If starting from scratch I would consider the total package. Type of supercharger, gears, and transmission will play a roll in off idle and low rpm throttle response also.
I would go with the lower pistons then mill heads to bring it up to ~10.2-10.3.
I have a new set of TEA Stage II 243s with a 65cc chamber. If I use the 243s,the Wiseco flat top would put the CR at 10.7. I also have a set of unworked L92s that I could use. I *think* the L92s have a 70cc chamber. Using the same Wiseco flat tops, the L92s would put me at 10.1. Not too far off from your recommended 10.2-10.3.
I hear you. I was all set just to move forward with the stockish 10.7 CR. Plenty of people have made that work. But, just out of curiosity I took a look at the compression ratios that the OEMs are using in their forced induction applications. Ford's GT500 is making 662hp with a 9.0 CR and the ZR1 is making 638hp with a 9.1 CR. They are making those numbers with OEM reliability and no meth. That made me rethink how I might move forward. I at least wanted to get some additional input on the subject before I pulled the trigger.
I'm running 9.7:1 now. I wouldn't go below 10:1 on a blower motor. Given the choice between the two I would do the 10.7 over 9.7 but I think right in the middle is a good spot.
9.9 to 1 here and would probably do the same again. I see no reason not to.
Thanks for everyone's input.
The ZR1 is bad *** no doubt. But....their fuel eco is crap and it takes them at least 1.5 and maybe 2X the boost to make the same power as an LS3 with a mild cam and bolt ons. The lower compression ratio used on the Z is purely a function of warranty and emissions. Probably emissions more so.
Also consider that the numbers you're quoting for the OEM's are flywheel numbers. A ZR1 typically dynoes 540 rwhp on a Dynojet. Just about any F/I build on an LS3 with bolt ons is going to be over that at barely over half the boost.
