C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Build v2.0
Old 11-02-2014, 05:54 PM
  #321
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Looks sick as hell man!!!
Love it!
JSB is my favorite color on vettes by far!
Sub'd for vids..
Old 11-09-2014, 09:11 PM
  #322
turbotuner20v
turbotuner20v's Avatar
Just FYI, the two pictures from lg motorsports are really different. I cut to match the first picture and had enough clearance for a test drive, but it rubbed the barrel of the wheel pretty bad and I had to remove a lot more material like picture 2.
Old 11-09-2014, 10:25 PM
  #323
inspector12
inspector12's Avatar
Yeah I did the same thing Jeff.
Old 11-10-2014, 10:24 AM
  #324
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
It depends on the wheels, and ride height, and how much you squat. The second picture looks a lot more like what I did.
Old 11-10-2014, 11:37 AM
  #325
turbotuner20v
yea, I'm pretty low and it squats pretty good on the DRMs and stock springs.
I bounced it around on the alignment rack and have a pretty good idea for where it's still to close, but it only touches on extreme dips or bumps as of now.
Feels good to have it aligned... I got the toe and thrust angle decent w/ a tape measure, but it still needed some work
Old 11-11-2014, 12:08 AM
  #326
1sc334
1sc334's Avatar
Originally Posted by turbotuner20v
15s are on... there was more grinding than I expected to get full clearance on the lower arm
LOOKS BEAUTIFUL bout how much u have n complete wheel n tire setup including spindles and do you think it was Totally necessary with ur setup or could someone get by on get a smaller wheel that would clear calipers with Good radials. ...even from a Dig.
Old 11-11-2014, 10:31 AM
  #327
turbotuner20v
I got the spindles and wheels/tires new/used for about $2350 I think it was. I happened to have the base brakes and caliper mounts, or that would be more $. I had to buy a sawzall and some grinding/cutting disks. The 17's and tires are more expensive than 15's though, so theres some cost saving there...
I really liked my 17's with M&H 325/45-17s. Honestly, with the torque curve of the new blower, I could have probably gotten by on the 17s for rolling 3rd gear starts. I may be able to get the 15s to work from 2nd though.
The ****** thing is, it just snowed for the first time in KS today... so my season is over. I'll have to wait for a nice day hopefully in the 60's to try some testing, but otherwise it'll be an experiment for next year.
Old 11-11-2014, 11:33 AM
  #328
Unreal
Unreal's Avatar
Spindles $1500
Wheels $450
Tires $500
Mount/balance $30
Used c5 brakes brackets/caliper $150
Pads $90
Rotors $140
That is what it was in parts to do 15s. If you add labor, probably add another $800-1000 for install of them.
Old 11-12-2014, 08:20 AM
  #329
ZO6er
ZO6er's Avatar
Should've come down to texas to "TnT" at RPR.....
Old 11-12-2014, 08:36 AM
  #330
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Looks great with the 15's. As you might remember I copied your 17 setup which I think looks great also. So far I am happy with the 17's but might be making some changes over this winter. I hope to avoid going to 15's but time will tell.
Old 12-06-2014, 08:52 PM
  #331
turbotuner20v
I came across a decent deal on a 3" cut down RSD radiator, so I picked it up. I have an idea for a revised inlet setup on the current blower or maybe making space for a future blower upgrade.
What are people doing for the fan/shroud setup on a cut down radiator?
Old 12-06-2014, 08:55 PM
  #332
redcycle13
Support Corvetteforum!
redcycle13's Avatar
I'm using a Dewitts dual Spal fan shroud, but my radiator is only cut down 2".
Old 12-06-2014, 10:14 PM
  #333
turbotuner20v
Did you buy the c5 one?
http://www.dewitts.com/collections/s...te-fan-upgrade
The c6 doesn't have a short version listed and is plastic
I could probably make a custom one or customize the c5 shroud
Old 12-07-2014, 02:10 PM
  #334
gotjuice?
gotjuice?'s Avatar
St. Jude Donor '13
I used the C6 one for my Dewitts cut down radiator. Had to mod the lower section a little, No big deal.
Quick Reply: Build v2.0
