What's needed to drop a walbro 450 into the stock fuel bucket?
#122
It is mainly for cooling. Once you hit say 750-800rwhp, the fuel supply needed is vastly increased. So to increase the supply you run the pumps harder. This increase in volume, will dead head when not used, creating pressure and heat. Any fluid movement that isnt doing work will create heat. By returning back to the tank it can cool down.
#123
A lot of big power setups run multiple pumps though where the additional pumps only come on when needed so I don't see how that would deadhead and create excessive.l heat. I guess your explanation only applies when you can't get fuel flow rate below some point due to the size of the main pump.
#124
1. Drill holes in bucket
2. connect wires
3. Dont need the Tiny small tiny hose
4. Dont need any regulator or block off
5. Let the filter hang outside bucket
6. Change the bigger hose to a submersible E85 hose
Ready to rumble?
2. connect wires
Ready to rumble?
#133
Boy you would hope he had it done by know. Post was 2017
#135
Been a few years now since this thread was started
Has anyone confirmed the runaway fuel pressure issue that racetronix mentions?
On E85 and on 93 octane fuels.
Any users who has had a failing pump or fuel pressure regulator?
#136
have a walbro 450 in mine. Bottom cut out of the fuel pump hat. No issues with fuel pressure and been running it for 3-4 years. Car is flex fuel and I run pump and e85 through it.
pierrel (02-02-2023)
#137
