Okay, so car has always started and ran perfect. Done a cam swap over the weekend. Started just fine initially. Drove it 2 miles, then suddenly my oil pressure, fuel gauge, and temp gauge went to 0. Got to the parts store and killed the car and unhooked battery cable thinking I would try re setting the ecm.*
Came outside several minutes later, hooked battery back up and when I hit the start button the instrument panel goes dead for a few seconds and then comes back on. So I thought dead battery, swapped batteries and still no difference . Iv checked all fuses and relays and have not been able to figure it out.*
Could this be a theft deterrent symptom?*
Info on my car
2005 c6 6 spd base
408 stroker f1r procharger
Yes,
Also the engine light stays on constant. Even when the car is completely turned off. And I hooked an obd2 reader and it will not connect to ecm.
It's looking like I have a bad ECM possibly
