C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
CC Venting?
Old Sep 16, 2014 | 08:19 AM
Realfast86's Avatar
Realfast86
Default CC Venting?
I have read many different threads about vent/catch can set up's for twin turbo's but still don't know what will be best for my build.
I planned on running 2 -10 or -12 lines one from each valve cover to catch cans then back into the fresh air side of the turbos I could also pull from the valley cover if that is a better way?
Old Sep 16, 2014 | 09:36 AM
turbotuner20v's Avatar
turbotuner20v
Vent the valve covers to a can with a filter, then vent the valley to a different can that also has a line to your intake manifold port (add a check valve if boosted)
Old Sep 16, 2014 | 11:10 AM
Realfast86's Avatar
Realfast86
So the valve covers dead end into the one can and the valley vent hits the second can and gets pulled back from intake vacuum that correct?
Old Sep 16, 2014 | 01:11 PM
turbotuner20v
Yup, valve covers to a vented can.
Then the intake manifold 'sucks' the vapor out of the valley plate and filters it through a catch can. Put a check valve in the line by the manifold so boost won't pressurize the crank case.
Old Sep 16, 2014 | 05:21 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
IMO if you have a built motor with FI ring gaps you need lots of CC venting. Much more than a typical catch can can provide. I have a -10 on each valve cover to a can with a large breather on it. Before that I would always push oil out the rear main.
Old Sep 16, 2014 | 09:37 PM
turbotuner20v
for sure... I pushed oil out my rear main until I added a -10 line and moroso catch can (in Bill's garage no less, lol)
Old Sep 16, 2014 | 09:56 PM
slow ride's Avatar
slow ride
Ditto, same as above. I ran my NA setup like that for years, but used just cheap 3/8 or -6 rubber line from the valve covers. With the turbo setup I have the catch can mounted by the air filter so it does pull in some of the stank haha
To CC Venting?
