C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
dyno fun
Old Nov 20, 2014 | 08:54 PM
Unreal's Avatar
Unreal
Default dyno fun
Made 1116rwhp on stupid low timing. Drinking beer and eating dinner. More details later.
Old Nov 20, 2014 | 09:50 PM
Unreal's Avatar
Unreal
Got to dyno, got all setup. 1st pull, 14 degrees timing maxed dyno out. It is a dynapak with bolt on hubs because all the local dyno jets can't hold >800rwhp. So tried to dyno in 5th but corvette 5th hits the speed limiter on the dyno so the only way to get numbers was to dial the tune back. Started pulling timing out until it got a reading. 11 degrees showed 1116rwhp/960rwtq. AFR was still whacked but after last pull 2 ribs of the belt came off (my stupidity) so that ended the evening. Will get a new belt on tomorrow and hopefully time to finish the tune but we will have to limp it along on this dyno to get a reading at all.
Old Nov 21, 2014 | 04:11 AM
venomws7's Avatar
venomws7
YSI? How much boost?
Great numbers.
Old Nov 21, 2014 | 08:50 AM
croatbob's Avatar
croatbob
pump/meth or e85?
Old Nov 21, 2014 | 08:58 AM
Unreal's Avatar
Unreal
It was actually blend of MS109 and 91, but ****, I was running less timing than I do on pure 91 daily, so I don't think that helped. Had timing at 11.
Peak boost was a bit over 22psi according to dyno, and 247kpa according to Map sensor on car.
Old Nov 21, 2014 | 12:22 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That's making some steam!
Old Nov 21, 2014 | 12:25 PM
Unreal's Avatar
Unreal
Doug, sent you an email about the belt issue with some pictures. Please help Got to get it all done by Wednesday for the race in December because I'm gone from the 26th to 10th.
Yes, car is making stupid power now. The airaid filter freed up 4psi which is a bit crazy.
Whats interesting is my inlet/filter/pipe testing. I thought the 4" pipe would pick up big power, but I got ~2hp out of it, barely anything. Basically same as before. ECS inlet pipe or 4" pipe made 1048-1050rwhp. So people wanting a 4" pipe and cut down dewitts/etc, if you have an ECS kit, it may not be worth it. Now PC or AA kits seem to gain a lot. The restriction on the ECS kit is actually the filter. 4" pipe with airaid filter made 22.5psi. Put the ECS filter on, and 18.5psi, back down to the 1050rwhp range. It is like a built in restrictor setup.
Old Nov 21, 2014 | 03:49 PM
ajrothm's Avatar
ajrothm
Did you try a pull with no inlet pipe on the blower at all?
Mine didn't gain much removing the filter only, but removing the long 4"/90* bend inlet pipe I picked up 2 psi. I ended up cutting the pipe in half removing most of the 90* bend...Now the filter sits almost above the radiator cover.. I went the DP big mouth filter at that point to.... Even with the changes, it still gains 1-1.5 psi with nothing on the blower at all..
Old Nov 21, 2014 | 04:15 PM
Unreal's Avatar
Unreal
No I didn't but my pipe is like yours, barely any bend, just a little 4" pipe.
Old Nov 21, 2014 | 04:25 PM
M M Alexander's Avatar
M M Alexander
Your car is making some serious numbers ... Curious to know what your short block consist of?
Old Nov 21, 2014 | 04:42 PM
Unreal's Avatar
Unreal
Fairy dust and unicorn horns
LSX block
Calles Dragon slayer 4" long snout
Coated bearings
Calles Ultra rods
Livernois/Ross coated top/skirts/etc pistons, steel upgraded rings
ARP stuff
Pat G cam
Old Nov 25, 2014 | 07:30 PM
Blue by U's Avatar
Blue by U
Nice numbers! What magical air filter was that? lol
Old Nov 25, 2014 | 08:54 PM
Unreal's Avatar
Unreal
Airaid Race Day filter.
Old Nov 25, 2014 | 09:27 PM
MOTOWN Z's Avatar
MOTOWN Z
Any pics of your build?
Old Nov 25, 2014 | 09:30 PM
383's Avatar
383
Video or it didn't happen
Old Nov 25, 2014 | 10:00 PM
Unreal's Avatar
Unreal
Just search my user name, too many pics and build threads.
Old Nov 26, 2014 | 10:02 AM
breecher_7's Avatar
breecher_7
Unreal is full of $hit... He has a nitrous bottle hidden someplace...
To dyno fun
Old Nov 29, 2014 | 07:29 PM
Blue by U's Avatar
Blue by U
Nice find
Old Nov 30, 2014 | 12:46 AM
drumacdy's Avatar
drumacdy
Man I'd love to try out that filter and pipe you have. I went to their web site and looked at the universal filters, is that what you got? You still have the part# for it? Is that pipe one from DP?
Old Nov 30, 2014 | 01:20 AM
GeneSch's Avatar
GeneSch
That is just unreal.
