C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Cam/Header, S/C Question...
Old Jan 12, 2015 | 08:20 PM
Chokeu's Avatar
Chokeu
Originally Posted by JaimeVrod
I went straight for the supercharger. Later, I added long tube headers and X-pipe which only netted another 25hp and 23 lb-ft of torque.
Where were you HP/TQ wise when you just had the S/C only? That's pretty much where I want to be, hovering around 600rwhp. Think i'm going to skip all the ******** and go right to the S/C, then add the headers/x-pipe on a later date and have it retuned. Seems to be the smart thing to do rather than getting a CAI only to have to sell it later.
Old Jan 12, 2015 | 10:17 PM
JaimeVrod's Avatar
JaimeVrod
On my LS2 with the A&A V3 Si w 3.8" blower pulley, boost a pump and 2 1/2" Borla axle back with a tune, manual transmission, I was at 552rwhp/476TQ. Adding the 1 7/8" LGM headers and 3" X-pipe brought me up to 577rwhp/499TQ. Both times, the car wass tuned for 93 octane fuel. You will probably have higher drive line losses with ASN automatic.
It is very hard to get traction so drag radials are my next mod followed by fuel system upgrade, 3.6" pulley and a retune. can and ported stock heads may follow.
Old Jan 16, 2015 | 12:24 PM
Chokeu's Avatar
Chokeu
Now is it possible to get 580ish rwhp without a S/C? Maybe cam, heads, headers, etc? Or is the price going to be too high to go that route as compared to a S/C.
Old Jan 16, 2015 | 12:30 PM
Chokeu's Avatar
Chokeu
Originally Posted by BOO666
If in stages def do ehaust with hi flo cats . Go catless with supercharger . If you are going for marginal power 1 7/8 headers . Buy used cai . Best one to get is halltech . Any one will work 103 and up with tune . Sell stock exhaust and put cash towards tune . Buy all this first stage used . Not new . Especially the exhaust . Some members are realistic with prices on for sale board . If you only want 580 to 600 . Port stock heads with eps custom cam and your there for stage II . Don't need a blower at all
So what your saying is I could reach 580 rwhp with a S/C by just doing: Headers, X-Pipe, CAI, Ported Heads, Cam, and Tune? If so, which would be cheaper? S/C kit or what I just mentioned?
Old Jan 16, 2015 | 02:07 PM
NormWild's Avatar
NormWild
No way you get to 580 whp with that set up, maybe upper 400s. To do NA right you will need cam, a GOOD set of aftermarket heads such as AFRs, headers, full exhaust, and a FAST. Add up all the parts to do it correctly and the labor to install it and you are right at the price of a super charger, but will be maxed out. A base kit supercharger will get you 550 whp with way more ability to continue to add hp in the future.
Old Jan 16, 2015 | 03:27 PM
Chokeu's Avatar
Chokeu
Gotcha, that's what I figured but just thought I'd ask. Thanks!
Old Jan 16, 2015 | 05:21 PM
Chokeu's Avatar
Chokeu
On a S/C setup, what size headers would work the best 1 3/4" or 1 7/8"? Is there that much of a difference? I would also want to do an X-Pipe, don't know if I should go with hi-flow cats or an offroad X-Pipe? Anyone have any suggestions? I am PUMPED, my car arrived from FLA this afternoon and is sitting in my garage just waiting for some mods!
Old Jan 16, 2015 | 10:26 PM
JaimeVrod's Avatar
JaimeVrod
Go with 1 7/8" so you have upside potential for mor power gains In the future if you made additional performance upgrades. Most tuners will advise you not to use a catted x-pipe with a supercharger because the cats will fail. I've heard this to be true even on stock ZR1 cars.
Old Jan 16, 2015 | 10:37 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Depends on power level on cats.. on the lower end of the supercharged spectrum cats can survive.. 700RWHP+.. not so much
Old Jan 16, 2015 | 10:50 PM
Chokeu's Avatar
Chokeu
So i guess the answer would be to go with the 1 7/8" headers for the possibility to make more useable HP in the future with more mods and to also skip the cats altogether. Thanks!
Old Jan 16, 2015 | 10:52 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You could run them at 580-600. Perhaps start without them, and if the gas smell bothers you, then give them a shot
Old Jan 16, 2015 | 11:56 PM
Streetk14's Avatar
Streetk14
My take on this after building, tuning, and owning three different blown LS cars:
1) Headers are a must in my opinion. Ditching the stock manifolds with a blower will allow you to run more timing at a given octane level, and it will eliminate the stock cats. The stock LS2/LS3 cats aren't known to last long with FI. I'd probably do headers before the blower if it's going to be one or the other right now. You don't get the bang for the buck that a blower gives you, but it's laying the foundation to make power.
2) I run high-flow cats on all of my header cars -- not because I need to for emissions reasons, but because I don't like my car to smell like my '68 Camaro did. They really don't cost any power at this level, but they are one other thing to worry about. But unless you plan to run the car REALLY hard at that ~600 RWHP level (i.e. half-mile drag racing), then I don't think I'd be worried about cat longevity. Cats also seem to smooth out the exhaust tone and reduce drone. Both are pluses in my book. With those bullets, it'll probably be a big plus for you, lol.
3) I'd recommend ARH headers based on my personal experience. Pfadt would be another choice now that they're back in business. I've had both brands, and each has things I like over the other. ARH seems to have better quality control, though. Either way, 1 7/8" is what I'd do for a blower car. I can't recommend LG headers, but I've had those too.
4) Really no need for a cam to meet your power goals. An ECS kit with headers should have no problem making what you want. Especially if you're considering meth. I've had two mildly cammed LS builds, and neither one drove like stock. So keep that in mind. Any cam that has noticeable lope is going to change how the car drives.
One of the nice things about a blower is that you can keep the driveability very much like a stock car. My current car has the stock cam still and I'm loving the stealth and manners of it. Seeing all the 700 RWHP cars ECS was building with stock cams made me a believer. If you really want more power, a cam is good for another 40 or 50 RWHP in most cases. The key is finding the happy medium where the car has usable power, and is still simple and reliable. Less is more sometimes.
Old Jan 17, 2015 | 07:58 AM
  #33
Chokeu's Avatar
Chokeu
Funny, I just got in touch with Don at SloHawk Performance in MA last night. He recommended the ARH 1 7/8" headers and no cats too. They also priced out an A&A kit with install and tune. He will be the one doing all my work most likely as he is the nearest tuner to me that has a good rep. Thank you, lots of great feedback here.
