What would you do ?
Prior to the failure the engine was.......
Stock cid
Stock heads and cam
ProCharger PS1 with 4" pulley and flip drive
Headers 1 7/8"
Marren 60# injectors
Typhoon aluminum intake manifold
Meziere electric water pump
Dewitts radiator with oil cooler
I am considering .....
Forged rotating assembly with 9.5 cr pistons, keeping my stock displacement (?)
Comp cams blower cam and valve train (need suggestions on this)
ARP fasteners
ATI balancer
Yella Terra rockers
Marren 80# injectors
D1 ProCharger
Meth kit (also need suggestions)
I need suggestions on the best timing chain. I cannot go double roller as I cannot space the timing chain cover due to the Meziere pump.
Any other suggestions/advice is appreciated.
I have a $6k budget.
I would keep the compression ratio between 10 and 10.5:1(stock is 10.9 on an LS2).
D1SC
Dual nozzle Alky Meth
Jam Cam kit from Brian Tooley Racing, this is going in my build but depending on how you want it to drive may not fit your needs.
10% OD balancer. I like my Innovators west balancer
C5R timing chain from Katech.
I dont think rockers are necessary.
Never heard of Marren Injectors. I'd use Injector Dynamics or FIC personally.
http://www.hinsonsupercars.com/p-294...ing-chain.aspx
BJK
Stock cid
Stock heads and cam
Headers 1 7/8"
ARP fasteners
ATI balancer
Yella Terra rockers
D1 ProCharger
Unless you're going all out, I'd try to keep it simple. Forged rods/pistons + stock crank if it's OK. Personally I'd do compstar rods and Wiseco pistons.
ARP fasteners are a given
ATI makes a nice piece. Whether it's needed or not, I do not know. I wouldn't be running the stock one, that is for sure (mine came apart on a base ECS kit in about 5 minutes)
Also not sure the rockers are necessary.
Is decent data available on them? Might consider ID's. Someone on here sells them pretty cheap. PM if you are interested.
Meth kit.. yes. Definitely. The Alkycontrol kit has nice braided lines, no push lock plastic stuff that can come off, so that is what I would (and am going to) get. FSP has a good price on the kit.
I have gotten some good pricing from Hinson on a Lunati crank and rods with Wiseco pistons.
From what I can find out, most steel cranks, even Callie, are forged in China, so I am assuming that is what we are stuck with unless your budget is north of $2500 for just a crank. Mine is not.
Looks like I will also be getting:
Clevite bearings
C7-R timing chain
ARP main and head studs
Comp cam
Lunati springs, steel retainers
The jury is still out on the exact compression ratio pistons, cam specs, damper (although Hinson has a good price on a Powerbond unit) and if I should send the PS1 ProCharger head unit back to the factory for a D1 upgrade or just pulley-down the PS1?
I am also thinking about the Comp Cam trunion upgrade.
I think with the above using the PS1 with a 3.4" pulley ( ProCharger said 14 pounds of boost) , a Meth kit and a conservative tune, I should be in the 650 rwhp range.
Experts, am I thinking right?
Clevite bearings
C7-R timing chain
Comp cam
I would certainly hope you end up with at least 650rwhp. People are making that on stock bottom ends w/meth.
I have no idea how how much either of those blowers will support though, so I am of little help there.
Is that what you are basically after ultimately, 650rwhp?
I ended up just upgrading my whole setup to handle much bigger power goals in the future also so I have tons of stuff leftover from my old setup if you want it, I'll make you a good deal.
the big intake upgrade is a great one and seems like you can do it cheaply if you just get the parts and do it yourself, a lot of guys have shown >40whp gains just from a bigger/better intake but also I spoke with someone at procharger just earlier today and they stated they thought a lot of high rpm belt slip issues with P1 and D1 setups on corvettes is from the restrictive intake and that guys who upgrade to a much bigger intake often see their belt slip issues go away and they gain as much as 2 psi of boost, so not just for hp reasons but for reliability and belt issues I'd recomend it.
I was having some minor belt slip issues with a 3.9" pulley (and 8" crank pulley) on my setup and am having the corner of my dewitts radiator cut right now so that I can run a huge 4" intake setup
Pulled the trigger on my parts today. Here's the list......
Lunati 4" forged stroker crankshaft. Should work out to 408 cid
Lunati H-Beam rods w/ARP bolts
Wiseco 20cc dished forged Pistons, 4.005 dia and a 9.6 compression ratio
Power bond steel balancer
Melling hi-volume oil pump.
CompCams trunion upgrade kit
Lunati .660 dual valve springs w/steel retainers
Marren 80# flowed and matched injectors
CompCam blower cam
Kooks 1 7/8" headers
Dewitt's radiator w/ EOC
Textraila clutch, flywheel kit including new hyd TO bearing
Cleavage H-series main, rod, and cam bearings
ARP main studs and heads studs
C7-R timing chain
ProCharger D1 w/ Intercooler
Meth kit ( to be determined)
Flip Drive
With a mild blower cam, meth, and 12 pounds of boost, I hope to see 650 rwhp
Probably be looking at a better fuel delivery system, too.
Thanks to everyone for their suggestions and advice.
Comments welcomed.
CompCam blower cam
C7-R timing chain
Comments welcomed.
I would consider going slightly higher on the compression ratio. Maybe 10:1 or even a little bit more than that.
Nice crank/rods/pistons. Most of this parts list is overkill for 650RWHP, but you'll at least be good to go if you ever want to turn it up some more.
How much did that clutch cost and how much HP (or torque rather I guess) will it handle, if you don't mind me asking? I am in the market for one and have been eyeing the Mantic 9000.
Can you post a part number for that balancer? Just want to make sure it's not the one I got that I ended up sending back.
Keep us updated with pictures!
I am going to keep the 9.5 Wisecos, as I can always crank up the boost on the D1.
Should have all the parts in a week or two, and I will post some pics.
I bough the clutch from Corvette Garage, a forum vendor that I have a history with. It is a Z06 clutch and flywheel, and with pilot bearing and new hydraulic TO bearing, I think the cost was in the $800 range. As I don't drag race or do burn outs, etc, this clutch should be all I need. Heck, the stock clutch went 76k miles and was still grabbing smoothly when the piston failed. The only reason I am upgrading is the motor is out of the car and now was the time to do it!
9.5:1 will be fine and will still vary depending on how much heads are milled, etc. Might as well change the clutch while it's out. I'm afraid to go too crazy on mine as I don't think it will last very long
Is someone else doing the assembly?
I, too, like "Cleavage" bearings
Damn spell check. Yep, a new clutch, flywheel and TO bearing is on the way.
