C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
procharger E85 HP?
Old Feb 6, 2015 | 06:26 PM
juicedz06's Avatar
juicedz06
Default procharger E85 HP?
what kinda power are you procharger guys (f1x etc) making on E85? obviously with supporting mods.....
also whats the best belt set up without issues, I hear lots of horror stories even with the dp set up, etc
Old Feb 6, 2015 | 07:16 PM
turbotuner20v's Avatar
turbotuner20v
1026whp ~24psi f1a94. 10 rib with direct drive on a procharger bracket and tensioner
Old Feb 6, 2015 | 07:42 PM
DSteck's Avatar
DSteck
User quickzoh6 made 1200+ whp at 19psi on a 444 F1X setup.
Old Feb 6, 2015 | 08:18 PM
juicedz06's Avatar
juicedz06
interesting, thanks guys.
Old Feb 6, 2015 | 08:20 PM
juicedz06's Avatar
juicedz06
hearing lots of belt issue horror stories even from a DP kit... what is best with no belt slip and shredding issues?
Old Feb 6, 2015 | 09:26 PM
turbotuner20v
Just don't run a cog belt. 10 rib should work fine. Who's having issues?
Old Feb 7, 2015 | 08:01 AM
DSteck's Avatar
DSteck
Chad runs a cog on a system from House of Boost. It's been completely trouble free, both when he had the manual and with the auto.
Old Feb 7, 2015 | 12:13 PM
FLTMEDIC's Avatar
FLTMEDIC
I'll be using a A&A 10 rib set up,ill let you know in about 4-6 months how it works out.Its taking a little while on my motor.Its a Briggs built Dart LS next with the mid sleeves with All Pro heads ect. ect.I'll be on E85.There are several big HP cars with F1-X's on both 10rib and cog that work great.If I were going COG It would be the HOB set up.
Old Mar 13, 2015 | 12:04 PM
chpmnsws6's Avatar
chpmnsws6
Add this to the blower and crank pulleys?
http://www.carbinite.com/Product%20I...manceTest.html
Old Mar 13, 2015 | 01:41 PM
Proace4's Avatar
Proace4
I won't be on e85. But, I will be running a cartek bracket with my f1x and 8 rib. pump gas/meth for main use, and c16/meth for when I need more.
Old Mar 13, 2015 | 02:47 PM
newschool's Avatar
newschool
10 rib and DP DD is all you need. If there is belt issues the alignment is wrong. We have a car making 1460rwhp with a F1x here with DP upgraded 10 rib DD system.
Bryan@AMP
Old Mar 13, 2015 | 03:41 PM
EX1's Avatar
EX1
Agreed. DP DD and 10 rib and you will be good to go.
Yo Bryan
Old Mar 13, 2015 | 03:51 PM
White_Lightning's Avatar
White_Lightning
a lot of issues come from cog drives + stick shifts in vettes..
I found the best thing for me was just take my car to Advanced Modern Performance in arlington Tx.. say " hey.. here is an f1x.. make this stuff work".. and then go back and pick it up once it was done by far the best automotive decision i have made..
Old Mar 13, 2015 | 05:18 PM
croatbob's Avatar
croatbob
10 rib is ur best bet
Old Mar 13, 2015 | 08:55 PM
Slo-Poc's Avatar
Slo-Poc
I like your style I just wanna feel the powaaa
Old Mar 15, 2015 | 09:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You forgot the part about writing a nice check
Old Mar 15, 2015 | 10:03 PM
White_Lightning
I learned the hard way.. Cutting corners and using amateurs for work ends up costing much more in the long run..
Old Mar 15, 2015 | 10:08 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
No doubt.
Old Mar 15, 2015 | 10:31 PM
chpmnsws6's Avatar
chpmnsws6
Writing it is simple. Them cashing it is where it hurts.
To procharger E85 HP?
