C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Stock C6 diff, single digits?
Old Feb 16, 2015 | 01:10 PM
Smoove's Avatar
Smoove
Default Stock C6 diff, single digits?
As I get closer to the end of this build phase with my car(tt C5) and onebadcads(f1x C6), I think I need some motivation to help get my a$$ in gear and finish the project(s). I was looking for that motivation living through you dudes that have tracked your C6 Z06(or cars with C6 Z06's diffs-C5 or C6). Primarily the single digit ones. We both run a late 2012(2012.5) C6 Z06 differentials and TR6060s. They both have stock C6 diffs. Just curious how hard you guys are launching these, at what power level, and what is the et you have been able to consistently hit without breaking. Traditionally I would walk the weak diff'd cars out of the gate but, I think if we're gonna try and legitimately hit 8's, I think we'll need a harder launch to get it out quick.
Info, vids,..whatever is appreciated.
Old Feb 16, 2015 | 04:05 PM
Shoaf85's Avatar
Shoaf85
I had stock C6 ZR1 trans and diff in my TT C6 car it went multiple 1.3/low1.4 60's and ran consistent low 6.1's @118 mph in the 1/8. Made 748/795 to the wheels with UPP TT kit. I used bias ply et streets and never experienced wheel hop cause I knew that would be the breaking point LOL
Old Feb 16, 2015 | 04:13 PM
ace32x's Avatar
ace32x
TT C6 running 6.1@118 at Farmington 1/8 mile dragstrip! - YouTube
this ^ stock zr1 diff holding up great on my car at 1100 wheel so far. did toast the stock trans though at 20k miles (11k modded)
Old Feb 16, 2015 | 04:39 PM
Smoove's Avatar
Smoove
ZR1's have 500m shafts, Z06 cars come with 300m,...correct? ZR1 is definitely a better unit,..which is something I do not have.
Old Feb 16, 2015 | 04:47 PM
Shoaf85's Avatar
Shoaf85
I'm not 100% sure on this. I thought the case was just a little different.
Old Feb 16, 2015 | 05:26 PM
Smoove's Avatar
Smoove
Definitely interested to know.
Old Feb 16, 2015 | 06:07 PM
winters97gt's Avatar
winters97gt
Base C6 differential, no brace or anything touched on the rear/tranny on my old C6. Fbody wheels out back with 295/45-17's, stock wheels up front. 800hp, 1.45-1.55 60fts, mid-upper 9's,
Old Feb 16, 2015 | 06:20 PM
LedfootLarry's Avatar
LedfootLarry
I think the ZR1 diff has the highest torque rating, then the C6Z06.
Maybe BlownBlue (Brett) can chime in on this, he seems to know these pretty well.
Old Feb 17, 2015 | 10:29 AM
Smoove's Avatar
Smoove
Word.
Whats the quickest stock driveline Z06 i guess should be the better question maybe?
Old Feb 17, 2015 | 08:18 PM
ajrothm's Avatar
ajrothm
Stock Z06 diffs do not have hardened shafts...(I don't think).. I see people popping shafts on them at the track all the time.. they will definitely break shafts.
I believe the ZR1s may be better but... I doubt they have anything other then 300m shafts...If that.
DSS is the only ones that make the "500m" shafts... And even they are not a true "500m" heat treated metal.
IF you drag race it, its gonna break..I'll guarantee that... You get any kind of wheel hop, its done.. You have to be VERY smooth on slipping the clutch. Sometimes they still break.
Glad to see you building one to go on the strip though...
Old Feb 18, 2015 | 02:31 PM
Smoove's Avatar
Smoove
Old Feb 20, 2015 | 09:38 AM
neverstop's Avatar
neverstop
maybe it's just my driving style or because I don't launch like I'm angry or something but I've had a number of cars with theoretically weak drive lines from nitrous honda to mustangs to 10 bolt rear ends on F body's and I've never broken serious driveline stuff even with 500 wheel torque on totally stock 2001 camaro driveline.
I don't know how often you plan to drag race it but I'd be surprised if someone out here hasn't snuck into high 8s on stock rear end. I bet if they do that more than a few times something is going to let go but if you're just trying to hit the track occasionally I bet you'll be fine if you slip the clutch a little and avoid wheel hop even if you launch it hard and I bet some big sidewall slicks will be key.
your car has insane power/torque under the curve so I'd guess could hit 8s with a 1.5-1.60 60ft?
Old Feb 20, 2015 | 11:33 AM
Smoove's Avatar
Smoove
I'm pretty decent with getting a car to work with fragile diffs or lack of traction. I never broke anything at the track(1ST MOTOR ONLY),mostly on the streets. I don't see why it couldn't 1.5 60 with a tire and decent launch/slip. I dunno if it'll get me 8s. I am HOPING it does but,...without knowing, only guessing. All the bushings/coilovers are all good so, I should have little movement in the driveline on launch. I know I have seen guys go 9's on stock C6 diffs(09 and up)..which makes me happy. I was just hoping the Z06 units are stronger.
I don't plan on racing it every weekend but,...truthfully, I would like to lol. Track or whatever. That's why I built this beotch It's been too many years of downtime for this ride.
To Stock C6 diff, single digits?
