C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ProCharger Direct Drive
Old Feb 20, 2015 | 12:11 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I will see how it goes for a while before deciding if I need to do the cog thing. On the dyno I saw no voltage drop, which I know doesn't tell the whole story. I also almost never use my AC. Maybe a couple of times a year, so that might get me off the hook.
breecher_7's Avatar
breecher_7
Originally Posted by Unreal
If you smile, wink, send some goodies I bet you could get them to do DP.
I had nasty issues with belt slip but only with mileage. <2k miles on a fresh ac and alt belt and all was good, get up there and starts to slip. Friend here had same issues. Belt kept whining and slipping, had to adjust it every few hundred miles.
Probably have 10K on the belt with no issues yet that ive seen.
I just texted Doug and he said he can do the DP drive as well. So I may send that out this winter yet and be done with it. Ive got some other gremlins to chase on that car anyways.
Old Feb 20, 2015 | 01:40 PM
StingrayRebel's Avatar
StingrayRebel
I wouldn't touch a DD without the cog mod. Only person doing that is ECS. Only system they will do that too is the cartek. So I would strongly suggest going with the cartek because if you get this (if it ever makes it out of legal issues) and you have belt issues with the alternator/ps/etc which are almost guaranteed, then you are kind of screwed. Only option then would be to sell this and buy the cogged cartek.
they have modded an a&a secondary drive, a guy in the c5 section had one done... it's business, I don't see why they would turn it down just because it's their competitors product... if anything else it would give them a chance to gain a customer
Old Feb 20, 2015 | 02:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
As I stated earlier, we can cog any of the renditions, if we sell it here it's a Cartek Flip drive.
Old Feb 20, 2015 | 04:56 PM
ajrothm's Avatar
ajrothm
Originally Posted by breecher_7
With the DP setup ive yet to see a voltage drop on logs man, just sayin....
The cogged stuff that ECS does is great, its a true "fix" to any type of belt slip. I need to talk to Doug and see if he can do it with the DP version as well. Its a better safe than sorry type scenario.
It can be done on a DP direct drive (which I agree is a better design then the cartek). Mine is being done right now by the inventor of the cog mod.
Old Feb 20, 2015 | 07:11 PM
Unreal's Avatar
Unreal
What I meant is if buying new should just buy the cogged cartek from ECS.
Yes ECS will do a DP one. Mine was the first one they did, just didn't want to put words in their mouth in case they weren't doing them anymore.
Old Feb 23, 2015 | 06:28 PM
Milan's Avatar
Milan
Originally Posted by DOUG @ ECS
I wonder if they even realize they are patent infringing on Cartek's Flip Drive?
I actually talked to an IP lawyer who came to speak to my MBA class about exactly this.
Cartek most likely is not willing to spend the $150-200k required to bring a patent suit against anyone they think is "infringing".
Also, unless it's a 100% replica of the flip drive they basically have 0 shot at winning.
Does Cartek already have the patent or is it pending? If it's pending you could still copy their exact product for 3 years (since their initial submission) and sell it without any risk. Patent Pending doesn't mean anything.
Old Feb 23, 2015 | 08:30 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Supposedly the patent has been granted.. but that's just what I've read
Old Feb 23, 2015 | 10:32 PM
Unreal's Avatar
Unreal
http://www.google.com/patents/US8408188
Old Feb 24, 2015 | 12:00 AM
Milan's Avatar
Milan
So it looks like it's granted.
Either way, it's simply way too expensive for them to enforce on their patents.
If this were the import world that design would have been copied 100x over by now and there would be a handful of different companies getting it made in China and selling the virtually the same thing.
Personally I don't think that the A&A secondary drive or the DP Direct drive infringes, I'm pretty sure they are different enough. If I was them I would consult with an IP attorney and continue selling, the flip drive is the shittiest of the 3 anyway.
Old Feb 24, 2015 | 12:27 AM
Milan's Avatar
Milan
Some other thought on the flip drive patent. I think it would only apply to those still using the factory 6 rib balancer. With an 8/10 rib the distal and proximal planes would be different.
Also because DP and A&A use different tensioners near the alternator, a very strong case could be made that their version are entirely different products. Also almost certainly their brackets in figure 13 are different.
Old Feb 24, 2015 | 10:25 AM
RpeterK's Avatar
RpeterK
The key to their patent is the re purposing of the 4 rib AC belt. The using of it to drive an idler which in turn drives the power steering and ALT. Its in the wording not the pics. The pics backup the wording. Doesnt matter what balancer is on the car. The belt path doesnt change. The patent covers the concept not just the brkts.
The thing I find hysterical is they dwell on how they use a hd stock tensioner for the belt that runs the power steering and ALT All this while using a 4 rib belt with the stock weak *** AC tensioner. You could put whatever tensioner on the 6 rib you want. There isnt enough wrap around the balancer now to drive anything really consistently. Think about the wrap that used to be available to drive just the AC. There was well OVER 180 degrees of wrap on c5 on both the AC and balancer pulleys. A little less on the C6. Now you only have about 90 degrees of belt wrap around the balancer and the work load has tripled.
Totally comical to announce a new product just about 2 years after a another company received a patent on it. Talk about way late to the party .
Old Feb 24, 2015 | 11:55 AM
  #33
Unreal's Avatar
Unreal
The single jackshaft with no additional tensioner on the PC system looks like a poor design. That is already an issue on the cartek/dp/etc that have the lower idler to put more wrap. That lower idler is also what lets you do a cog setup later, by adding the eccentric to use that to tension the cog, so without it I doubt the PC system could be cogged.
Old Feb 24, 2015 | 02:27 PM
  #34
Milan's Avatar
Milan
Honestly all of these systems have faults. The only complete solution is what ECS offers
Old Feb 24, 2015 | 02:43 PM
  #35
Unreal's Avatar
Unreal
Agreed which is why I would only use/recommend that one.
