E-Force question
The install guide mentions a supplied MAP sensor harness - looking at my kit I only have the wiring for the intercooler pump assembly.
Does anyone have a picture and part number of the MAP sensor harness?
Thanks.
I will be installing an LS3 Eforce kit into my 2005 LS2 Corvette. I am already aware of the MAF sensor change and found the adapter harness for it - as well as the delphi to bosch change on the MAP sensor change as well - but I am not sure what harness I will need to go from the Delphi harness > Bosch harness > FoMoCO sensor on the back of the blower.
Specs on my car:
05 LS2:
GMPP CNC ported LS3 heads
LS9 cam
LS7 lifters
Kooks Long Tube headers
Vararam Intake
Corsa 3" Z06 exhaust
60 lb/hr fuel injectors
PCM of NC tune
The car runs fine and I am putting 450 to the tire.
I am adding a 1591 LS3 blower kit that I have.
Looking at the kit - I am missing the MAP/TMAP sensor harness, and maybe a harness for the MAF sensor (I can't tell if one is supposed to come with it).
I know I need to convert to the LS3 MAF sensor - and I found this adapter from
Speartech:
http://www.speartech.com/product_p/ls3mafadapter.htm
Will that adapter work?
Now I need to find an adapter/harness for the MAP/TMAP sensor.
The sensor on the back of the blower says FoMoCo on it.
This adaptor from Speartech will go from the Delphi to Bosch.
http://www.speartech.com/product_p/mapext.htm
Will I need to go from the OEM > Speartech > Edelbrock harness?
Sorry for the 50 questions - I am just now starting to get into this and getting all the information that I need.
Thanks,
Craig
