C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Users With PLATE Kits!
Old Apr 15, 2015 | 08:55 AM
Denis_C6-Z's Avatar
Denis_C6-Z
Default Users With PLATE Kits!
What plate kit did you go with? What does our set up consist of?
I am debating on the NX VS Nitrous Outlet but the plate kit alone is a big difference in money, why is this?
I would like to buy a complete set up and not have to piece by piece together a kit.
Who's the cheapest when it comes to buying the kits from?
Why did you choose the kit you did vs the other?
Old Apr 15, 2015 | 03:29 PM
scotts94_z28's Avatar
scotts94_z28
Always used Nitrous Outlet kits myself but i'm seeing only like a $20 difference between the kits.
Old Apr 15, 2015 | 03:36 PM
Denis_C6-Z's Avatar
Denis_C6-Z
How do you figure? The NX plate kit I can get for $570 shipped, the outlet is $875, that is $305 in just the plate kit, the other products are about the same price give or take a bit...
Old Apr 15, 2015 | 03:42 PM
scotts94_z28
I see the NX at $720 and the Nitrous Outlet at $699. The NX plate kit at $570 would be a no brainer for me as long as it is as complete as Nitrous Outlet plate kit.
Old Apr 15, 2015 | 10:18 PM
Denis_C6-Z's Avatar
Denis_C6-Z
Originally Posted by corvette8189
apples to apples
Retail is NX 720 with 10lb. bottle NO is 799 with 10lb. bottle
That said anybody needing anything NX pm me.
Does the NX kit come with hard lines and vehicle specific solenoid brackets? Any pictures of the kit installed? I want to pull the trigger on your kit but just working out all the last details!
Old Apr 16, 2015 | 10:13 AM
Denis_C6-Z's Avatar
Denis_C6-Z
No hardlines in the kit. They can custom make you a hardline kit if you want though. They have a couple different options for solenoid brackets.
http://www.nitrousexpress.com/solenoid-brackets.html
They should have some pics on there website. If not ill see if I can find some.
The braided lines will work just fine, the only bracket I am seeing is this Part # 15770, can you confirm it is for LS engines and will work on an LS7?
Old Apr 16, 2015 | 01:24 PM
Denis_C6-Z's Avatar
Denis_C6-Z
On the LS7 #15770 will take some work to make it fit as on the LS7 there is a sensor in that location. For the LS7 they just came out with a new bracket that mounts them on top of the intake.
That will not fit under the engine cover correct?
Old Apr 16, 2015 | 01:31 PM
Denis_C6-Z's Avatar
Denis_C6-Z
Trimming most likely needed.
bummer, would like to hide them and not have to trim anything up!
To Users With PLATE Kits!
