Quick question: When I was at 630 RWHP on 3rd gear and at approx. 6000 RPM range, WOT, the car felt like it was cutting off and the car would not shift until i let off for a few seconds. Past 3rd if I remember correctly the car shifts fine...
Note: The tranny does flare a bit mainly on 3rd...
Hopefully someone can answer this question for me..
Not long after first installing the blower a few years back, my car was doing the same. It would flare when driven hard and the trans temp would get a bit elevated.
Added B&M external trans cooler with a fan - resolved the flare issue.
What are your transmission temperatures with the cooler?
Can you send me the part number please?
Cooler is always a good idea as mentioned. If it is a 6L80, check the fluid and overfill the trans by 1 quart after full.
