C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS Boosta a pump Hob switch question.
Old Jul 22, 2015 | 10:11 PM
GeneSch's Avatar
GeneSch
Default ECS Boosta a pump Hob switch question.
I have another question....LOL
I know I ask a lot but as they say, measure twice and cut once.
As I'm installing the Alky kit I figured Id check over everything.
In testing the hobbs switch on the ECS Boosta a pump I have a question. When I installed it I did add the racetronix wire upgrade.
So when checking the switch I find that it is a normally closed switch. So the connection is allowed to pass to ground until the switch reaches 4lbs.
Is this correct? I was under the impression that when 4PSI was reached it would close the switch and allow the circuit to become complete but it seems to disconnect the circuit instead. I checked it with a volt meter and it is closed until it reaches 4lbs....
I did not disconnect the switch from the system and test it. It is still wired up. I just put a jumper from each leg to the volt meter.
File Type: mov
Old Jul 22, 2015 | 10:42 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I had always thought the same.. so I'm a bit confused if it's backwards from that. But I know electronics can do some weird things sometimes so I would try testing it totally disconnected and see what happens.
Old Jul 22, 2015 | 10:55 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I don't remember exact details, but I do remember that the hobbs from my ECS kit worked opposite to the hobbs from the BAP, and I was surprised to find that out.
Old Jul 22, 2015 | 10:56 PM
telly444's Avatar
telly444
blow some air through the switch and put a multimeter on your fuel pump power wires.
Old Jul 22, 2015 | 10:59 PM
GeneSch's Avatar
GeneSch
I will have to do that. Batt is disconnected at the moment. I just don't remember if the ground switch deactivates or activates the boosta pump
Old Jul 22, 2015 | 11:06 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yeah, I really need to look into this.. because if it really does work backwards from the hobbs switch I bought then it isn't doing much
Old Jul 23, 2015 | 01:20 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
That is correct, the Hobbs switch opens the circuit during boost.
Which is opposite of our fuel system Hobbs switch just so that is clear.
The thinking when that voltage booster was designed is that if a ground failed it would increase the voltage all the time, which is better then going lean and possibly hurting the engine if it didn't turn on at all anymore.
If you were to by pass the hobbs and short it right to ground the booster will do nothing, leave it off it should boost the voltage all the time to 17.4v then. Which is the value we figured out to give a nice boost to the pump without burning it out.
Other brand BAP's can increase voltage to 21+ volts which will burn the pump out quickly, hence part of the reason why BAP's kind of have a bad reputation.
I hope that helps!
Old Jul 23, 2015 | 03:06 PM
GeneSch's Avatar
GeneSch
Thanks Doug!
That's what I was thinking you guys probably did. This way it it's not hooked up or a wire is broke it will fail on the safe side. Good idea. Thank you.
Old Jul 23, 2015 | 03:25 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I needs to do some investigatin'
To ECS Boosta a pump Hob switch question.
