C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
meth suggestions
Old Sep 18, 2015 | 11:14 AM
maiettar1's Avatar
maiettar1
Default meth suggestions
So I was thinking about scooping the meth kit from ECS as well. but I am hesitant because I am mechanically challenged I want as low maintenance as possible when it comes to the car. I'm not really looking for the extra power, just want to keep the engine safe. Is their kit a "set it and forget it" kind of kit or is it something I am going to have to constantly mess with? Also is the added power something I have to worry about? IE am I in danger of pushing the stock engine, trans, rear to its limits? Do you also smell any of those fumes inside the cabin of the car?
08 Z06 18k on it
ECS 1500 SC Kit
redone heads(valve issue addressed)
Old Sep 18, 2015 | 12:18 PM
Pitufina's Avatar
Pitufina
I just installed mine last weekend. I would say is just install and forget, and since you are thinking like I did, my suggestion is to do it. I didn't make any changes to the tune and ended setting the gain **** on 6. I went from running 11.01@119 to 10.54@134 with just the meth. Well worth in because the ecm pulls timing due to the high IATs. Also buy the breakout wiring to run the ZR1 IAT sensor on the intake right behind the throttle body. Plenty of threads on this forum if you search. Good luck.
Old Sep 18, 2015 | 12:22 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
08 Z06 18k on it
ECS 1500 SC Kit
Once it is installed the only thing you have to do is fill the meth tank, usually every 2-3 tanks of gas depending on driver habits. Adding will make a little more power, but you can leave everything the way it is and just add it for safety.
It will also help with retaining the power year round.
Old Sep 18, 2015 | 04:28 PM
neverstop's Avatar
neverstop
it's virtually 'set and forget" if done right, with single nozzle you rarely have to refill and it's a good idea to change the pump every few years but some guys don't and they're usually fine. if you don't tune the car to rely on it I think it actually improves reliability a lot and it's cheap to do.
Old Sep 18, 2015 | 11:24 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I keep thinking I've got to be close to running out.. then go to fill it up and it's not even close to empty. More like 2/3 full. I'm using a single nozzle, so I'm sure that helps
It's very low maintenance. Dump some more in every now and then and there ya go. Meth gets low away from home? Stay out of boost and it doesn't matter in the least.
Old Sep 19, 2015 | 09:36 AM
TTZ06VETTE's Avatar
TTZ06VETTE
...or stop at the local CVS and add a little distiller water until you get home!
To meth suggestions
