C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
launch control for a nitrous car
Old Sep 23, 2015 | 08:47 AM
curtisb23's Avatar
curtisb23
Default launch control for a nitrous car
not realy sure on how this would work with an nitous car if my nitous is to come on from rmp/tb how do you get is to not spray when you atavate the launch control? witch controllers are people using and liking the most
Old Sep 23, 2015 | 10:34 AM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
I was researching nitrous stuff a while back and found that there are some controllers out there (like the nx maximizer 4) that have a MPH window for activation as well. Might be worth looking into.
I have no experience with it because I never pulled the trigger on anything, so I'm curious to hear what other have to say.
Old Sep 24, 2015 | 07:20 AM
curtisb23's Avatar
curtisb23
bump
Old Sep 24, 2015 | 09:21 AM
js23881's Avatar
js23881
Default Nitrous Controller
Originally Posted by curtisb23
bump
Look at the programable Edlebrock Nitrous Controller. Its simple to use and works well.
Old Sep 24, 2015 | 09:39 AM
curtisb23's Avatar
curtisb23
im intrested in a lanuch controller and how they would work on a nitrous car setup,i have the mini progressive already
Old Sep 24, 2015 | 09:49 AM
Dude_man's Avatar
Dude_man
What rpm do you typically launch your car at?
Old Sep 24, 2015 | 09:55 AM
curtisb23's Avatar
curtisb23
depending on track or street .track 5to6k street 4 to 5k depending on the prep, my nitrous is to come on at 3k an full throttle
Old Sep 24, 2015 | 09:59 AM
Dude_man's Avatar
Dude_man
Spraying at 3k!? any reason why you spray so low in rpms?
Old Sep 24, 2015 | 10:09 AM
curtisb23's Avatar
curtisb23
i guess just incase the car bogs on a bad launch and what not,sometimes do some roll races and my rpms are about 3500
Old Sep 24, 2015 | 10:18 AM
curtisb23's Avatar
curtisb23
i was just reading on my mini progresive it has a delay timing for when it comes on after being triggerd to use with a launch control . anyone do this?
Old Sep 24, 2015 | 10:29 AM
brodyscorvette's Avatar
brodyscorvette
If you're hooking, that's not all that low.
Old Sep 24, 2015 | 10:34 AM
Dude_man's Avatar
Dude_man
Thats a lot of unneeded stress on the bottom end IMO
Old Sep 24, 2015 | 11:58 AM
Nitrous Express & Snow Performance's Avatar
Supporting Vendor
Max 4 Progressive controller
http://nitrousexpress.com/15957-maxi...ontroller.html
The Maximizer 4 progressive nitrous controller operates one or two separate stages of nitrous based on either time, RPM, MPH, throttle percentage or boost pressure.
Let me know if you have any questions.
To launch control for a nitrous car
