C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
how much does cool air affect performance
Old Sep 30, 2015 | 09:18 AM
vettandtyphoon1's Avatar
vettandtyphoon1
Default how much does cool air affect performance
On blower cars how much difference in et would a 90 degree day vs say 60 make ?
Old Sep 30, 2015 | 09:42 AM
whatcop?'s Avatar
whatcop?
From: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
Depends on the tune. I believe most safe tuners don't allow the car to add timing for cooler air so you start losing power around 75* IAT.
That being said cooler air is more dense so you make more boost and make more power that way. I've seen my PD blower car fluctuate from 15.8-17.4lbs which could be about 20-40hp.
Old Sep 30, 2015 | 09:47 AM
old motorhead's Avatar
old motorhead
All else being equal, try about 1% more or less for every 10 degree temp change. How much difference in ET would vary based on how much hp you're working with...weight of car etc.
Old Sep 30, 2015 | 09:53 AM
Pitufina's Avatar
Pitufina
If the dense air can help to create more boost, wouldn't the tune be on the lean side? Would the fuel trims take care of such a "big" change?
Old Sep 30, 2015 | 11:24 AM
vettandtyphoon1
I'm at 714rwhp
Car goes 10.4@139
1.8 60'
vettandtyphoon1
In 90 degree heat
Old Sep 30, 2015 | 12:22 PM
Unreal's Avatar
Unreal
Depends on tune, meth, etc. Could be a 200hp difference or basically none. Go dyno it and find out.
My car makes the same power if it is 70 or 110 out. Doesn't pull timing until 140, and meth keep sit below that, so it doesn't care really about outside temps as far as power goes.
Old Sep 30, 2015 | 12:49 PM
Pitufina's Avatar
Pitufina
Originally Posted by vettandtyphoon1
I'm at 714rwhp
Car goes 10.4@139
1.8 60'
You need traction. 1.8 60' is leaving quite a bit on the table.
Old Sep 30, 2015 | 02:55 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Fuel trims can adjust about 25%, though they aren't really used at WOT (technically positive fuel trims can be carried into WOT/PE fueling but negatives fuel trims are ignored in WOT/PE)
The "Density" part of "speed density" comes from knowing the temperature of the air. Lower temp = higher density, which means the computer knows there is more oxygen, so it adds more fuel accordingly
Higher temps, lower density, less oxygen-->less fuel needed
PV=nRT basically
So.. it should work itself out. Does it perfectly every time? Hell if I know.. it's close on mine but not perfect. Mine goes slightly lean at higher IAT's, slightly rich at lower IAT's. I've just richened it up a few % and left it alone. Air temps fluctuate too much here for me to feel like constantly tweaking it
Old Sep 30, 2015 | 03:47 PM
old motorhead
Outside air temps really don't matter. The temp of the air going into your motor is what does matter. Intake air temps. If it's 60 degrees outside and you're not moving much (sitting in line at the dragstrip), the intake air temps may be WAY over outside air temps. That temp is what influences your power output more than outside air temps.
Old Sep 30, 2015 | 04:33 PM
Dude_man's Avatar
Dude_man
But your intake air temps are greatly affected by your outside temp...
Old Sep 30, 2015 | 05:49 PM
old motorhead
With 60 OAT's (outside air temps), you can see intake air temps WAY below that using meth. Sit in line at the drag strip, with no meth, and you may may see 120+ degree IAT's. Big power difference between the two with the same tune and the same 60 degree outside air temps.
Old Sep 30, 2015 | 07:22 PM
Dude_man's Avatar
Dude_man
And you can leave a bag of ice on your intake while waiting... But that's not what the OP is asking. I don't believe his question mentioned meth at all.
My iats drop instantly as soon as I start moving, even on the dyno with almost 100* temps and extreme humidity
Old Sep 30, 2015 | 07:45 PM
slow ride's Avatar
slow ride
Let's not forget how cool temps bring engine coolant temps down which might allow more spark advance etc.
Old Sep 30, 2015 | 07:51 PM
ajrothm's Avatar
ajrothm
1-2 tenths from 90* down to 60*....assuming the humidity and baro pressure is the same.
You really need to compare density altitude from day to day, that will average all of the weather characteristics and tally them up for you for an easy comparison.
This isn't even talking about additional boost/timing etc etc.... This is just basic NA engine gains, which should easily be matched by a FI engine combo.
Old Sep 30, 2015 | 09:16 PM
old motorhead
My point was that 40 degree or 110 degree OAT's....the only thing that matters is what kind of intake air temps the motor actually sees. Whether that's influenced by OAT's, air flow, position of earth in relation to Mars, or meth. Doesn't matter.
Old Sep 30, 2015 | 09:43 PM
Dude_man's Avatar
Dude_man
You said "Outside air temps really don't matter." which isn't true because OATs have a huge impact on IAT, is what I was saying.
To how much does cool air affect performance
Old Sep 30, 2015 | 10:08 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You're all wrong
All that really matters is manifold air temps
Old Sep 30, 2015 | 10:12 PM
Dude_man's Avatar
Dude_man
Originally Posted by schpenxel
You're all wrong
That's why I relocated my IAT sensor to my manifold
Old Sep 30, 2015 | 10:17 PM
Unreal's Avatar
Unreal
You're all wrong
Can go one step farther and say cylinder air temps.
