Nitrous Stutter/Buck On Hit
Just a little history on the car. Its a 2008 a6 ls3 with stock fueling. Nitrous is set up on a window switch. I previously had a 5th gen ls3 integrated solenoid plate system on my car and it ran great. Ran it at the track on a 150 and made some good passes but when it got dyno'd on the 150 it only made an extra 102whp/72wtq. I threw a 200 in it and tested it out and that too ran perfect but no dyno/track time.
So I ordered a 90mm plate kit from NX to try and get some more power out of it. I got it all hooked up today and decided to start out with the 200 pills. On the hit the car stuttered/bucked super hard so I immediately let out of it. I figured it was just too much nitrous and thankfully nothing got hurt that I know of. Stepped it down to a 150 and it did the exact same thing. At this point I checked to make sure both solenoids were firing and they both did. So I put a 50 shot in it and again on the hit it stuttered/bucked and let out. I tried it one more time but this time stayed in it and after bucking/stuttering a couple times it pulled fine. I decided to try throwing a shorter fuel line (7in vs 23in) on the solenoid to plate. My guess was that the nitrous was getting to the plate faster than the fuel. Went for a test hit and there was no longer a buck but just a very small stutter on the hit. I tried adding a foot of line to the nitrous line (2ft line now 3ft) but it didnt make a difference.
So Im thinking if I make the nitrous line even longer say 5ft total would that fix my problem? I really couldnt think of anything else so any input would be great. Thanks!
Heres some pics of the line lengths.
Dumb question, but you've checked to make sure that the jets are the right way round, correct? Don't ask, but that has happened before...
I'm not sure whether you're experiencing a stutter or a rich stumble from the mixture being rich on the initial hit. The fact that you had a lot of gunk in the N2O inlet screen at first would seem to indicate that the buck you were initially getting was from the mixture being too rich?
Are you using a controller? If so, does it have a fuel offset feature? If so, try adjusting that. If not, I would invest in a good controller anyhow.
Also, I've seen this sort of thing happening before on an LS1 car where the plate was mounted backwards and the nitrous was being sprayed forward towards the MAF. I'm not sure how the NX plate works, but you can check that as well. NX makes top notch stuff, from what I've seen, and I've used them all over the years.
Good luck and I hope that you get it sorted soon.
Happy foggin!
Happy foggin!
Going to the track tomorrow to see if my trans will be happy with it or not.
You certainly have a cold enough plug and the gap is tight enoug for sure. I know a lot of people will advise that you should run the non-projected plugs, but I don't like them for street use.
I've run up to a ~200 shot (.082" jet IIRC) on my 6.2 A6 AWD Sierra Denali with 7IX Iridium plugs on 93 Octane pump gas with no issues.
BTW: I just re-read your original post and was reminded that you're using a window switch. Depending on how that's activated and working, it may be that could also cause a stutter on activation of the system. Just a possibility, stranger things have happened...
As far as the transmission is concerned, one thing you might experience with the bigger shot is that the transmission will not shift fast enough and this will cause the engine to bang up against the limiter instead of shifting. This can be taken care of by tweaking the low gears shift speed (mph) tables in the TCM tune. These transmissions are torque input sensitive and the more power you put in them, the more you will have to compensate by telling the transmission to shift early. You also want to tweak the shift times to shorten the time it takes to complete each shift, because you want to limit the amount of time that the clutches slip on the shift. Tuning is critical with these transmissions, especially with FI/N2O on these cars.
Good luck and keep us posted.
Awesome let us know what you run.
