C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Understanding timing?
Old Oct 19, 2015 | 09:08 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default Understanding timing?
05,A&A ti trim blower,alky meth,LT'S,z06 bimode exhaust....using dashlogic .
Watching timing while driving yesterday.
High gear/low rpm= 50-60*
Lower gear/high rpm=10-18*
Just trying to understand what I need to be looking for or concerned about?
Old Oct 19, 2015 | 09:16 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
The low RPM #'s seem high to me
I usually see around 13-14* towards the top end so that sounds about right
Keep an eye on knock retard
is it the stock cam?
The basic idea is you want peak cylinder pressure to happen about 15* after top dead center.. At WOT there's a lot of air/fuel in the cylinder so the explosion (flame travel speed) will happen faster. Thus, you want to delay ignition so that you still end up with peak cylinder pressure closer to (or after) 15*
At light throttle there's not very much fuel/air in the cylinder so you have to start the process sooner as the flame front will travel much more slowly. Thus the high numbers at part throttle stuff.
I assume you don't have HP Tuners?
Old Oct 19, 2015 | 09:25 AM
C U IN REARVEIW
Stock cam,no hp tuner,get some knock in 6th gear lugging it....but nowhere else.
Old Oct 19, 2015 | 09:54 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Probably a bit too much timing down low but not a huge deal IMO. I see the same sometimes if I jam the throttle real quick down low. The knock sensors are quite sensitive. When my power steering pump was going out it was loud enough to set them off like crazy
Here's a video on knock/detonation that I really liked:
Old Oct 19, 2015 | 12:08 PM
C U IN REARVEIW
https://www.youtube.com/watch?v=WuCUGcqO5SE
I watched this in another thread you posted it in....very informative. Thanks again for your help as always.
To Understanding timing?
