C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
eforce and meth
Old Oct 27, 2015 | 02:57 PM
veloz's Avatar
veloz
Default eforce and meth
contemplating adding a meth kit to my stg II eforce LS2...i contact eforce directly and they respond:
Do NOT use methanol injection as it will damage the rotors and housing. We’ve had superchargers come back to us that look almost melted after they’ve been injected with methanol
Sooo, whats the next best thing out there to reduce IAT in an eforce or an alternate method for the meth in an eforce?
Old Oct 27, 2015 | 11:02 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Ran Meth through my eforce for 3 years. Rotors were fine.
Old Oct 28, 2015 | 07:50 AM
veloz's Avatar
veloz
so what mixture did you run through? and were did you install the nozzles?
Old Oct 28, 2015 | 09:33 AM
old motorhead's Avatar
old motorhead
I've been running meth, and various combinations of meth and water, through Eaton blowers since 2005. Several hundred thousand miles easily. I've yet to see any ill effects. Easton's "official" stance obviously is....don't use it. I'm guessing they encourage any of the aftermarket companies that use their rotor groups to adopt that same stance. Hence, you won't find an aftermarket manufacturer (Edelbrock, Magnuson, etc) that will tell you it's OK to use.....even though it is
Upgrades to the heat exchanger and coolant pump will probably help more with IAT's than meth. Meth will give you more octane to work with though.
Old Oct 28, 2015 | 09:41 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I was running 50/50 water/meth...
Not my car, cant find a pic right now.. but like this....
Old Oct 28, 2015 | 09:57 AM
veloz's Avatar
veloz
can u elaborate on the heat exchanger and pump? what exactly are the options?
Old Oct 28, 2015 | 10:55 AM
old motorhead
If you can find a ZR1 pump, it's a nice upgrade. I've used Mezziere (I'm sure I butchered the spelling) pumps too, but they didn't last very long.
Magnuson's Heartbeat uses a good heat exchanger on their new kits. Should be a bolt in with few fitment issues. The ZR1 guys use it with good success. I'm using it on my Heartbeat system. IAT's don't go up as high and recover faster vs my other TVS based builds. Probably not completely and solely due to the h/e, but I believe it's an upgrade for just about any older TVS based kit.
Old Oct 28, 2015 | 11:14 AM
veloz's Avatar
veloz
hmm, i will look into that...
how about adding RP Purple Ice Super Coolant in the blower reservoir? i use it in my engine coolant and it really works...
Old Oct 28, 2015 | 11:20 AM
old motorhead
Yeah, also use the minimum amount of anti-freeze you can get by with. The coolant additives work better with straight water, but I realize that isn't practical due to climate for some folks.
Old Oct 31, 2015 | 01:37 PM
BowtieBilly1121's Avatar
BowtieBilly1121
Can you use the meth/water injection with out having to retune your car with out a loss of power?
PS What is the best meth/water system to use? Thanks
Old Oct 31, 2015 | 06:36 PM
old motorhead
The higher the percentage of meth you use, the more you need a retune. My take on it anyway. I didn't retune my truck with a Maggie TVS2300 when I added low temp WW fluid injection. It occasionally showed a little KR before, so it probably was tuned a little aggressively anyway. It's about a 50/50 mix of water and meth. I use a Snow system for that one. No KR now.
I spray 100% meth in my Vette with Heartbeat TVS2300. I did get that one retuned. It's an Alky Control setup. That's the only way to go if you're spraying straight meth IMO.
To eforce and meth
