C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
alky control help asap guys please!!!
Old Nov 21, 2015 | 10:29 AM
C6vettegfw's Avatar
C6vettegfw
Default alky control help asap guys please!!!
Ok guys in the pic below I have a few questions. Ok guys the harness in my hand between my thumb and finger is there another piggy tail connect that this connects too? Is this where the led test light plugs into? And also is this where the supplied map sensor ties in. If this is the case I need to cut it and solder the lines back on. Please need help asap. I have a ferry to catch in five hours!!!!!
Old Nov 21, 2015 | 10:30 AM
C6vettegfw's Avatar
C6vettegfw
Here the pic I'm talking about.
Old Nov 21, 2015 | 10:41 AM
booztd3's Avatar
booztd3
you should have a harness the plugs into it . http://www.alkycontrol.com/#!product...2-f713016f98f3 ------look at the picture
Old Nov 21, 2015 | 10:44 AM
booztd3's Avatar
booztd3
you can cut the connector and hardwire it if you had to .
Old Nov 21, 2015 | 10:47 AM
C6vettegfw's Avatar
C6vettegfw
Ok thanks. There was no harness included in the kit.
Old Nov 21, 2015 | 10:55 AM
C6vettegfw's Avatar
C6vettegfw
Ok so it seems I'm def missing the brass t and the harness for the pac controller. I'm heading to Napa for the t fitting now do I guess I'll just have to hard wife the rest of the things in
Old Nov 21, 2015 | 11:31 AM
TTZ06VETTE's Avatar
TTZ06VETTE
Julio at Alky Control can send a replacement I'm sure
Old Nov 21, 2015 | 05:44 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Most of the wires on that connector you won't use anyways, so I just cut it off and added new connectors that only included the wires that are used
Old Nov 23, 2015 | 07:13 PM
timmyZ06's Avatar
timmyZ06
Well actually only the purple and grey aren't used if plugged like ECS recommend. There's few ways of doing it but you deff missing a connector harness
Old Nov 23, 2015 | 07:14 PM
timmyZ06's Avatar
timmyZ06
LED is orange and brown
To alky control help asap guys please!!!
