C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
intake manifolds
Old Dec 10, 2015 | 08:16 AM
curtisb23's Avatar
curtisb23
Default intake manifolds
too keep my fast intake or go back to the oem ls2 intake manifold?. iv been seeing videos and pics of cars running the fast intake with blowers seeing these are starting to change my mind and keep the fast ????ideas anyonne?
Old Dec 10, 2015 | 08:35 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I think its a matter of luck. Some guys have no problems, and some do with boost. Since you can make all the power you want with the stock one, I would sell it, put money in my pocket, and not have to worry about it.
Old Dec 10, 2015 | 08:39 AM
Unreal's Avatar
Unreal
Money in pocket and to put towards other mods is much nicer than a liability of something that may or may not hold together.
I wouldn't be surprised is FAR more are leaking or damaged than people know, they just never check or open them up. Local guy came in down on power, leak checked his car. Big leak from the main oring on the fast, and when opened 2 of the runners where broken off and just laying in the bottom of the intake.
Old Dec 10, 2015 | 08:48 AM
curtisb23's Avatar
curtisb23
yeah good idea .if it blowes apart ill be out all that cash
Old Dec 10, 2015 | 02:54 PM
irok's Avatar
irok
Default Operator error
that would be operator error on the installation of the Fast
Old Dec 10, 2015 | 03:14 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
For some reason I don't believe nearly every installer screwed up the install.
Old Dec 10, 2015 | 04:37 PM
Unreal's Avatar
Unreal
Way too many for that to be operator/installer error.
Old Dec 10, 2015 | 06:53 PM
Icevettez06's Avatar
Icevettez06
If you have Fast 102mm I would stick with it. I can take 30psi.
Old Dec 10, 2015 | 07:55 PM
curtisb23's Avatar
curtisb23
I would definitely make more power off it
Old Dec 11, 2015 | 12:31 AM
neverstop's Avatar
neverstop
ssinister made i think 1,500whp through stock ls7 intake and Arun has gone deep into the 8s on a stock ls6 intake.
Old Dec 11, 2015 | 12:32 AM
neverstop's Avatar
neverstop
WOW that's a crazy story. incredible the thing just fell apart internally. I don't remember the shop but some big name shop (vengeance?) on here had a FAST literally explode under boost and since then they only run the OEM intakes or metal on the boost builds.
Old Dec 11, 2015 | 08:05 AM
C6 Curtis's Avatar
C6 Curtis
Holley EFI Hi Ram > ALL
Old Dec 11, 2015 | 09:06 AM
curtisb23's Avatar
curtisb23
was thinking this,if i could find another black hood id concider it and cutting a big *** hole in the hood lol
Old Dec 14, 2015 | 07:33 AM
curtisb23's Avatar
curtisb23
what yall think about the holly intake
Old Dec 14, 2015 | 07:58 AM
Unreal's Avatar
Unreal
Great intake. Have to cut a lot more than just the hood. Have to cut the cowl and remove wiper.
Old Dec 14, 2015 | 09:22 AM
sr20dime's Avatar
sr20dime
St. Jude Donor '15
Yep! Actually I did a lot of testing with the Highram and fast 102 on my FI setup. The Highram picked up power above 5500 over the Fast but lost around 150 ft lbs below 5000. That worked out for me because I needed to kill some torque to help traction when launching.
You do have to cut the cowl but it looks like the wipers can go back.
Old Dec 14, 2015 | 09:41 AM
slow ride's Avatar
slow ride
Do you have any data from that at all? It seems like a good idea to extend the powerband up top since all the bottom end torque doesn't help when you are spinning haha.
To intake manifolds
Old Dec 14, 2015 | 10:30 AM
sr20dime's Avatar
sr20dime
St. Jude Donor '15
I have a dyno at my house so I play with part changes all the time.
I have lots of data and dyno sheets.
I'm traveling to Korea for work right now but I'll post the results when I can.
Old Dec 14, 2015 | 10:45 AM
slow ride's Avatar
slow ride
What the what that is awesome. I've actually thought about doing that in a shop in the future
Old Dec 14, 2015 | 11:04 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Dyno at your house? Where do you live again?? lol
