C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Procharger Head units
Old Dec 16, 2015 | 03:17 PM
JK363's Avatar
JK363
Default Procharger Head units
I have a 2007 Z06. Heads are done, cammed, 1 7/8"s headers to 3" exhaust. I want to be 800-850 whp. Looking at the procharger kits. Which head unit would be better the D1sc or F1c? Not looking into tearing into the motor at this time. Maybe next winter to forge it.
Old Dec 16, 2015 | 03:59 PM
JetstreamGS's Avatar
JetstreamGS
D1SC is plenty for what you're looking for although A&A or ECS kits are preferred over PC around here.
Old Dec 16, 2015 | 04:47 PM
Detoxx03's Avatar
Detoxx03
I love the ProCharger headunits. 850 can be doable just depends on the rest of the combination.
Old Dec 16, 2015 | 05:27 PM
neverstop's Avatar
neverstop
850whp is pushing a D1SC but 800whp is easy imo. 850+whp can be done but you'll be on the outer limits of it's capability. I'm at 865whp on a D1SC on a LSX Block 427 with MAST black label heads and baby cam with 91 octane pump gas and a ridiculous amount of methanol but I'm getting belt slip on my 8 rib setup at ~6k rpm. I have an older A&A procharger bracket though which for now has the weaker tensioner then they ship on new kits so that may be part of it but I find that 850whp seems to be close to the limit for what a normal 8 rib kit can do, much above that and I think you need a flip drive. the only person I found making more whp than me on a D1SC was also having belt slip.
ECS and A&A both make great great kits though that will get you what you want with way less hassle and lower price than procharger. that would be the direction i'd go.
Old Dec 16, 2015 | 07:12 PM
JK363's Avatar
JK363
Yours is way more built than I was planning on doing. I was going to see if I could achieve this on pretty much stock rotating assembly, a good cam, worked heads, and good fuel. Probably E85 for the summers. Change to gas when it starts getting cold in the fall. I have a pretty good line on a F1c set up with 8 rib and flip drive. No fuel. Was debating it with some of my friends.They felt as the F1 would be too big for where I'm at now and that I should go D1. I figure I could run lower boost and step up as requirements allow.
Old Dec 16, 2015 | 07:22 PM
nareg's Avatar
nareg
Just get a F1X, you will want more later. This is of course coming from someone who has a D1sc going bigger.
Old Dec 16, 2015 | 08:10 PM
JK363's Avatar
JK363
Yea Id rather buy one head unit. Just worried that an F1 platform won't work too well with my current engine set up and a small fuel system.
Old Dec 16, 2015 | 08:23 PM
Detoxx03's Avatar
Detoxx03
I would just get the F1C. Hell I wish I had one right now. You will inevitably want to forge your bottoms end and make more anyway.
Old Dec 16, 2015 | 11:51 PM
neverstop's Avatar
neverstop
if you're going with a flip drive anyway than i'd just step up to the F series blower if it were me
I doubt your setup will react that differently than mine with same blower given we both have the same displacement and you'd likely have a bigger cam since my cam is conservative. you probably have higher compression than me so you may even do a touch better from that too. I don't think the heads make that big of a difference.
Old Dec 17, 2015 | 02:48 AM
StingrayRebel's Avatar
StingrayRebel
a&a makes a great procharger bracket, I highly recommend them to the op if you decide to stick with a procharger headunit... I have a d1 on my c5 and the last time it was on a dyno it was in the 720's seeing 12psi... since then I have added an overdrive balancer, smaller pulley, secondary fuel system and now seeing 16psi and the impeller speed is about 52.5k rpm at redline so it isn't being spun very hard... haven't had it on a dyno since making those changes but I would guess it to be in the mid 800's... at that power level and seeing that it isn't being spun very hard, how much more room do you think is left in that blower?
Old Dec 18, 2015 | 01:13 AM
neverstop's Avatar
neverstop
I have looked pretty hard and not found too many D1SC setups making much over 850whp on 6 speed cars. There seem to be a handful but it's not common. Depends a lot on the whole setup and the tuning and of course which day on which dyno. I don't think I found any D1SC that was >900whp. I think Champion had a car that came close with high 870s through an auto but they had a flip drive.
I have innovators west big 8 rib crank pulley and 3.55 blower pulley and theoretically it should hit max impeller rpm at 6800rpm but it seems to nose over a little at about 6k rpm and not totally clear to me yet if my car is experiencing belt slip or if the compressor map is just past it's efficiency. Procharger does not release compressor maps so even though we know what max impeller RPM is we don't know where max efficiency is.
Old Dec 18, 2015 | 01:40 AM
StingrayRebel
now I'm definitely curious what it would max out at... I will get mine on a dyno early next year and see what happens but if the car is where I think it is that's kinda weird it wouldn't make much more with a 3.5 pulley which would max out the impeller speed at redline on my setup... I also have an innovators od balancer, secondary drive, and the blower is 10 rib so that helps... I really don't think I will push it any harder than I already am, if I ever build another motor I might shoot for 900rw, maybe swap to an f1a-94... but that's down the line if I blow my stock motor up, as of now I'm satisfied with how it is
Old Dec 18, 2015 | 03:01 AM
nareg's Avatar
nareg
If you have a D1sc and want to make 800+whp you will need to spin the blower 60k+rpm.
Old Dec 18, 2015 | 10:11 AM
JK363's Avatar
JK363
I agree with you. A&A does make a nice bracket. What motor are you running it on?
Old Dec 18, 2015 | 10:35 AM
StingrayRebel
Originally Posted by JK363
I agree with you. A&A dies make a nice bracket. What motor are you running it on?
stock block/heads ls6... I have the newest bracket with hd tensioner and it has given me zero issues since being installed, it was simply a bolt on and go deal... no shimming/extra machining needed like I had to do with the other guy's stuff
Old Dec 18, 2015 | 11:05 AM
JK363's Avatar
JK363
Stock rod and pistons too? If so thats awesome. Must have a huge fuel system.
Old Dec 18, 2015 | 11:13 AM
StingrayRebel
yep, has a cam but the rest of the rotating assembly is stock and never been touched... I'm using an a1000 as a secondary pump, meth, and big injectors so fuel isn't an issue
To Procharger Head units
Old Dec 18, 2015 | 12:00 PM
JK363's Avatar
JK363
Nice! Thats pretty much what I want to do with my build.
Old Dec 18, 2015 | 04:02 PM
neverstop's Avatar
neverstop
do you have any dyno sheets or testing data showing this Nareg? I've been all over these interwebs looking for dyno sheets of overspun D1SC showing big whp but have yet to find one as it seems they all end up slipping the belt.
the problem in my mind is that with D1SC and other procharger blowers we know where max impeller speed is but we don't know where the most efficient impeller rpm is, and those things are not necessarily the same at all especially with a D1SC which has a relatively small "frame" or inlet or whatever you want to call it.
I will say the torque on my D1SC setup on my 427 is pretty strong though and comes on pretty dang hard in early rpm.
Old Dec 18, 2015 | 04:06 PM
neverstop's Avatar
neverstop
sounds like an awesome setup Neutron, >800whp through a D1 on stock shortblock and heads is impressive. I'm in for dyno results, very curious to see what your torque curve looks like and especially what the whp curve looks like at 6k+ rpm. You sound like you really know what you're doing but of course i'd make sure they don't use much correction factor on the whp curve so you can see what belt slip you may or may not be having at higher rpm. 10 rib and driver drive is going to be huge benefit here for you.
I'll have my car back on dyno with upgraded tensioner and better pulley alignment in late January too so I can post that up as well and will be interesting to compare.
I also run lower compression than you, I think this motor is 9.75:1 or 10:1 so you've got some compression over my setup
A&A customer service is top notch too imo
