You do need harden valve seats and guides as well as change the oil more often. E85 will bring more water into your oil, but with proper maintenance this should not cause problems.
Having to run pumps that are E85 compatible
Fuel mileage
Can be dirty to run (have to change my fuel filter every 3 months). External filter is a must IMO
How much more often are oil changes? After pulling it out of storage for sure in the spring and when the DIC say 50%? 70%?
I've personally been a dumbass and let mine sit for like 3 months, which I wouldn't recommend. Unless you like replacing fuel components. Realistically I wouldn't let it go for more than a month. Get a flex fuel sensor and be done with it. That's next on my list since I'll be working out of state soon.
Drain it and run 93oct through before parking it for long periods.
huh.... I can see this with older cars or carburated applications. But around here I haven't heard anyone complain about e85 over the winter. I made sure everything was topped off in the tank as to remove any airgaps.
I suppose I'll find out in spring on that front. I do plan on doing flex fuel tho.
What about the oil change interval tho?
Pull out your injectors after sitting for a winter and have them flow tested. A good friend of mine ruined a set of id2000S that way. I'll never chance it when it's so easy to just drain it or run 93 with a flex fuel sensor
I always heard about not letting it sit but just haven't heard a specific time frame. Got the flex fuel stuff setup already.
