C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Methanol (is this normal)
Old Jan 21, 2016 | 01:34 PM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
Default Methanol (is this normal)
Car yesterday after sitting for a day tells me "check windshield washer fluid". Okay fine it's low. First off, I thought it was kind of bizarre that it was after sitting and not after the last time I got on it.
I filled it up this morning. I checked on it ten minutes later it was still full. I now went to check on it four hours later and it's not up to the brim any more.
Do I have a leak? I don't see any large puddles or anything underneath the car. Where's some obvious places to look if there was? Is it possible I really was empty and it was showing higher than what it was because of a potential air pocket and now it's dropped down and I have nothing to worry about?
Old Jan 21, 2016 | 01:37 PM
OhioC5's Avatar
OhioC5
Just a guess but I'd check to see if it's leaking at the pump. I had a similar issue on my GN. I think the leak so so small the methanol would evaporate.
Old Jan 21, 2016 | 01:41 PM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
Wonderful. I meant to state the obvious that there's nothing underneath the car.
I have the half mile event in two days great timing...
Old Jan 21, 2016 | 01:46 PM
neverstop's Avatar
neverstop
hard to say without knowing how much it went down but it does evaporate pretty quickly if sitting and the cap isn't tight.
my car sometimes goes a few weeks or more without driving and I know there is no leak and if I park it filled up to the brim, when i come back out to my car a few weeks later the meth will be down to the bottom of the neck sometimes where i can't even see it, but when I fill it back up it's just the neck.
i'd check for a leak though, for me at least i would really not NOT want to have a methanol leak on my car. that stuff burns clear and is obviously super flamable.
Old Jan 21, 2016 | 01:51 PM
Dude_man's Avatar
Dude_man
I had the same thing happened to my Sti, like the others have said it does evaporate fast. Which is nice if spilled on certain things.
Old Jan 21, 2016 | 03:43 PM
MARSC6's Avatar
MARSC6
I would guess the rubber seal for the meth pump intake line in the washer tank. It drips down onto the inside of the fender and evaporates before it can puddle up enough to make it to the ground.
Old Jan 21, 2016 | 03:53 PM
1MEANGS's Avatar
1MEANGS
Agreed, been there done that a couple times already... Meth pump is shot, I'm sure Matt has one on the shelf that he can swap for you before the event. It's literally a 20 min job if you know what your doing!
Old Jan 22, 2016 | 08:50 AM
Nosferatu's Avatar
Nosferatu
St. Jude Donor '14
well considering by the time I posted this I had to be at work in an hour or two it really limited me on what I could do...
I did notice (which wasn't there earlier) a slow drip coming from where the pump would be. The whole underbody of the car in front of the driver side door was all wet. I had a friend drive the car down for me to his shop and I guess we'll see.
Perfect timing...sucks for both me and FSP that it had to happen now. I guess better yesterday than on Saturday (day of the event)... :/
Old Jan 22, 2016 | 08:55 AM
NormWild's Avatar
NormWild
My pump head was leaking a month after I put it on. It's a given you will have to replace it every couple of years, seals degrade. I keep a spare handy, swap takes 15 minutes, send the leaker back for a rebuild.
Old Jan 22, 2016 | 09:21 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree.. I'm about to order a spare so I can swap it out.. then send the original back for a rebuild.
Old Jan 22, 2016 | 12:20 PM
RPOWU8's Avatar
RPOWU8
I had a rubber cap on the pump that split and was leaking. All I had to do was replace the rubber cap.
DJ
Old Jan 22, 2016 | 08:38 PM
JetstreamGS's Avatar
JetstreamGS
That is unacceptable in my opinion and the reason why I'm still on the fence putting a kit on mine. Every few years I could put up with but it seems a lot of them fail prematurely.
Old Jan 23, 2016 | 10:58 AM
NormWild's Avatar
NormWild
15 minutes every 2 years for 50 hp and insurance your motor won't grenade? Sounds like a pretty good trade off to me. Plus it's way more than 50 hp in the summer, more like 100. I love running into guys that "are on the fence" with Meth, lol.
Old Jan 23, 2016 | 11:24 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I would bet for every one that you hear of leaking there are 50 that are just fine. Ok maybe not 50.. but you get my point. You don't hear from people when they don't leak.
I still think swapping out the pump once a year is the best way to do it. After you have two pumps then you're just paying for a rebuild which isn't much
Old Jan 23, 2016 | 12:09 PM
Dude_man's Avatar
Dude_man
Walter white approved
Old Jan 23, 2016 | 12:12 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Best show ever
Old Jan 23, 2016 | 12:29 PM
Dude_man's Avatar
Dude_man
Originally Posted by schpenxel
Best show ever
I just started watching it last month, I'm on season 5
To Methanol (is this normal)
Old Jan 23, 2016 | 12:50 PM
JetstreamGS
I will pull the trigger eventually I'm sure. Just discouraging when reading threads like this. Failure after a month leads me to believe there is a quality control issue. I would be livid if mine went that quick.
Old Jan 23, 2016 | 02:14 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Failure after a month def. isn't the norm
Old Jan 23, 2016 | 03:02 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
My alky kit been on for 3 years and never had an issue. Maybe not running pure meth is easier on the pump.
