Hi,
I was planning to install 2008 NPP mufflers from an LS3 on my 2005 base C6 that wasn't equipped with NPP mufflers. It occurred the me that if the vacuum solenoids are actuated by engine vacuum, then on a forced induction engine, such as mine, they will also see boost under hard acceleration. I'd like to know if the boost has caused any problems with the actuators, like causing them to fail. Please tell me how many miles you've been using your NPP mufflers with a supercharger, how much boost you're running and if it's caused any failures or other issues.
Thanks for the input. Looks like this project is a go. I think the Z06 NPP actuators are the same as the LS3 actuators, so I think it should be reliable for the most part.
How are you tapping into engine vacuum and will the hose pop off under boost? I assume a hose clamp is needed.
No problems here. ECS, 10 psi or more.. if you're that worried about it add a 1 way valve so they never see boost.
All depends on how you want them to operate and how you're going to control them
I added a tee to the hose that connects to the blow off valve on the intercooler. Then just ran a vacuum hose through the driver side rocker panel, through rear wheel well. Add a splitter there to split it down to two smaller hoses and connected those to NPP valves.
That's brilliant. I didn't think about the intake tract being under vacuum. I was thinking I had to tap vacuum behind the throttle body or on the intake manifold.
Also, I'm not that concerned about damaging the solenoids with the positive feedback I've been seeing here. I just wanted to make sure wasn't going to go down a proven path to failure. Cheers.
i just run mine off the "NPP In a box" kit so it's 100% manual turn on and off for my car and then i just double sided taped mine to my methanol controller which sits right by my right knee. tapped for vaccum by just t'ing into the brake booster line which took about 1 minute
I considered tapping into the brake booster line as well but was a little concerned about diminished brake performance since I sometimes do HPDEs. Im probably just overly cautious.
Yeah it won't hurt anything. On the ECS kit they splice into the brake booster hose to connect up the hobbs switch for the boost-a-pump and blow off/bypass valve.
The plastic connector that the brake vacuum hose connects to on on brake booster has a one way valve built into it, so it will store whatever the highest vacuum it sees is
My vehicle came with NPP from factory and using those in the past along with my B&B Fusion currently (also has same type of setup) and no issues at all.
I did the (npp in a box) kit on mine. Was working great til we Dynoed it (blower)....now won't close the valves....can't seem to find the issue. Thoughts?
The dyno procedure I believe requires an 02 sensor to be inserted in the exhaust. So they need to deactivate the actuator so the exhaust gases only come out one muffler outlet on each muffler. The probably disconnected the vacuum line to do this and They probably didn't reconnect the vacuum source to the solenoids when they were done.
Just make sure that if you are using an aftermarket controller instead of a factory equipped NPP that you open the valves before going into boost. They are not designed to be closed except for under 3000 rpm causing and idle.
It will only be closed for cruising with the wife (she doesn't like hand acceleration /horseplay )....open all other times
Hi,
Not at all with 10-11 psi.
I don't think the mufflers will give a darn whether the valves are closed or not. I think the only failure susceptibility would be the actuators and everyone on here seems to think there is no or very little issue/concern. I'm willing to give it a shot.
