Better option than ls3 water pump?? Ls9?
Water pump pulley broke on me and seems to have taken out the water pump. Is there and direct replacement for it that may be a better option. Seems like the ls9 water pump would be more suited for our force induction needs but I'm not sure if I would have to modify anything to get it to work. Also can the pump be replace with out blower bracket removal?
08 ls3
A&A kit and bracket with procharger
Ati 8 rib kit
Ls3 pump to ls9 pump?
Or
Ls3 pump to electric?
08 ls3
Ati 8 rib kit
Or
By broke do you mean the pulley came off? I always tack weld them to make sure they don't. Never see many problems with the stock pumps.
Yes always tack weld the pulley to the shaft with an SC. I'd just get an new LS3 and weld it.
Evans Water Pump ( special milled for sc, must talk to evans about this) and then Meziere, ive had both.. You have to remove the entire sc bracket for install, the blower has to be pulled out the way at least... But the entire bracket will be removed to put on the new water pump.. Just did this a few months ago.. Get some water pump gasket maker to help hold the wp gaskets while you place the wp on the car.. Also make sure the wp is 100%
I think Mez is better at idle but Evans flows insane at wot..
Evans
Meziere
Evans
Meziere
https://www.google.com/url?sa=t&sour...1D9m8fxfkrdvWw
I have had all 3 pumps obviously stock with FI mez and evans..
Lol love this forum asks for better option.. OP gluck
For the record he bought another stock LS3 unit.
Arctic Vette (02-01-2016)
