C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Compression and E85?
Old Jan 30, 2016 | 09:27 PM
usmcpony's Avatar
usmcpony
Default Compression and E85?
What are some of the advantages or disadvantages of running higher compression on E85. Some shops are telling me to run 9.5:1-9.7:1 and other shops are telling me to run 10:1-10.5:1 since I'm running E85. The motor is a ERL 427CI 6 bolt block with 1/2" studs and All Pro 12-1 heads. I currently have a Paxton Novi 2200r supercharger (billet YSI). I'm probably switching to a F1x or possibly a twin turbo setup. My car is a street car so drivability is very important.
Old Jan 30, 2016 | 09:56 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Upgrading already.... how was the 2200R..... did you get to use it ?
Old Jan 30, 2016 | 10:14 PM
usmcpony's Avatar
usmcpony
Thinking about it. Not set in stone yet.
Old Jan 31, 2016 | 12:28 AM
Detoxx03's Avatar
Detoxx03
I wouldn't run anything in the 9's on E85.
Old Jan 31, 2016 | 03:19 AM
JetstreamGS's Avatar
JetstreamGS
I wouldn't go that low on pump nevermind corn. High 10's at least IMO.
Old Jan 31, 2016 | 06:01 AM
Unreal's Avatar
Unreal
If it is not flex fuel, and never going to see pump, no reason to dick around with low compression.
Upgrading before things are done is a quick and easy way to get frustrated, never finish, and hate your car.
Old Jan 31, 2016 | 07:31 AM
usmcpony's Avatar
usmcpony
Originally Posted by Unreal
11:1+.
Winter blend is E70. So I'll most likely go with flex fuel. I don't drive the car in the winter. I'm just worried about getting a lower octane than E85. Especially in late fall or early spring. I plan on running E85 as much as possible.
Old Jan 31, 2016 | 09:04 AM
Unreal's Avatar
Unreal
E70-e85 doesn't matter.
Old Jan 31, 2016 | 11:18 AM
Detoxx03's Avatar
Detoxx03
E70 is leaps and bounds better than 91/93 octane.
Old Jan 31, 2016 | 11:25 AM
C6 Curtis's Avatar
C6 Curtis
Id say 11.1 and higher. I run 13.8:1 on E85 and boost and have for months now. I have done plenty of pulls and no problems. If it's an E85 only car personally I would go as high as possible.
-Curtis
Old Feb 1, 2016 | 04:33 AM
usmcpony's Avatar
usmcpony
-Curtis
13.8:1? I thought only N/A cars ran that much lol. You're braver than I am.
Old Feb 1, 2016 | 08:50 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
E85 ftw
I don't have a dog in this fight.. but I sure as heck wouldn't even consider anything under 10:1
Old Feb 1, 2016 | 09:34 AM
Dude_man's Avatar
Dude_man
Old Feb 1, 2016 | 02:21 PM
EX1's Avatar
EX1
What are you 1000+whp blower guys running on E85?
Old Feb 1, 2016 | 02:29 PM
dsp300c's Avatar
dsp300c
I'm 100% on E85 and on my new motor (sleeved 388ci LSA) I went with 11.4 compression based on recommendation from friends and the builder. I have an F1X and hoping to make 1150 since I stayed with a 4 bolt block. Car also has dual nozzle meth.
Old Feb 1, 2016 | 02:33 PM
Dude_man's Avatar
Dude_man
I like the sounds of that build
Old Feb 1, 2016 | 02:47 PM
C6 Curtis's Avatar
C6 Curtis
+1 sounds like a winner to me
To Compression and E85?
Old Feb 1, 2016 | 04:43 PM
dsp300c's Avatar
dsp300c
thanks. should have numbers soon. I could have gotten the lsx block for about the same price but I didn't want the added 120lbs or the ability to make big power 1400+. i wanted to handicap myself so i keep enjoying the car b/c most 1400+ cars get parted out or sold. i went with the CA 625 ARP head studs to hopefully hold the heads down better.
Old Feb 1, 2016 | 05:17 PM
Detoxx03's Avatar
Detoxx03
I will also cosign that.
Old Feb 1, 2016 | 07:10 PM
usmcpony's Avatar
usmcpony
The crank is already balanced for -18cc 9.7:1 pistons. I'm just going to mill the heads to 10:1. Decided to go with the All Pro 12-4 heads with 1" deck thickness.
