C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
multiple mis-fire APS TT
Old Mar 14, 2016 | 06:05 PM
koji77's Avatar
koji77
Default multiple mis-fire APS TT
All,
I have an 06 Z06 with APS TT kit. I am making 966rwhp@17 lbs boost.
A little while back the car started running rough until she seemingly warmed up. I put new coil packs, wires and plugs in and still the same.
I just got from under the car and round that the connection on the drivers side front 02 is badly melted.
could this cause the random multi- misfire?
thanks in advance.... other than that I am going to swap out the crank position sensor.... running outta ideas here.
Help!
Old Mar 14, 2016 | 08:43 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Couldn't have been helping with part throttle fueling.. Replace it and see what happens.
Old Mar 15, 2016 | 12:55 PM
Pekka_Perkeles's Avatar
Pekka_Perkeles
It should throw a code/SES as well. Unless front o2's (error codes & SES) are disabled.
Old Mar 15, 2016 | 02:09 PM
koji77's Avatar
koji77
Only code I get is the flashing engine symbol signifying multi random mis fire. I do not know if the code/ses has been disabled.... I'll get HP tuners and see.
gonna get to that damn wire by this weekend!
Old Mar 16, 2016 | 04:29 PM
Dude_man's Avatar
Dude_man
i had this happen after driving through a puddle. The O2 sensor wouldnt trow a code, but when hooking up a tech2 or hp tuners I was able to see it wasnt working correctly.
Old Mar 17, 2016 | 10:13 AM
koji77's Avatar
koji77
just started pulling things apart... should have her tore down by this week end.
Does anyone know of an install video is... I can deduce what to do.. but seeing how things were done would definitely help out.
Old Mar 17, 2016 | 10:27 AM
Dude_man's Avatar
Dude_man
Pulling what apart?
Old Mar 17, 2016 | 11:05 AM
koji77's Avatar
koji77
I've gotta drop the drivers side just to get to the 02 connection that burnt/badly melted.
I have a random mis-fire and this is what I discovered. Because it's so tight the only way for me to get to it is disassemble the drivers bank... PITA!!
Old Mar 17, 2016 | 11:23 AM
Dude_man's Avatar
Dude_man
Wow... That sucks lol good luck
Old Mar 17, 2016 | 12:41 PM
inspector12's Avatar
inspector12
Man I wouldn't hassle with that O2. That's a lot of work for that. Id turn them off and see if the misfire goes away first. Parts swapping to find an issue should be a last ditch attempt. But you can still do a number of things with the car together and running. Like log the cam count to make sure the cam sensor is reading, also if the car won't start without a crank signal I believe. It will start with out a cam sensor though. More than likely its that O2 they like to blink to tell you your probably hurting the catalyst etc...
Old Mar 22, 2016 | 01:02 PM
koji77's Avatar
koji77
okay,
If I disable the front 02's wont she over-fuel? And you are saying that because it's running it's more likely the cam sensor not the crank?
I appreciate the info and diagnosis.
Old Mar 22, 2016 | 01:10 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Why would it overfuel? Without an O2 sensor signal it will just use the MAF/VE tables and not make any adjustments beyond that. If the MAF/VE tables are close then it will be fine.
If it's getting a WRONG O2 signal from a burned wire or whatever, then it could be making adjustments the wrong way currently.
I'd rather have no O2 signal than a wrong one (I actually unplugged an O2 sensor on mine a few weeks ago when this happened to me--used an impact wrench installing the sensor and I guess that ruined it. Fuel trims were maxed out and the car barely ran it was so rich. Disconnected it and drove home just fine)
I'd try it and see what happens.
Do you have a wideband on it?
Do you have HP Tuners?
Old Mar 22, 2016 | 01:38 PM
koji77's Avatar
koji77
I have HP TUners.. no wide band. I will do as you instructed and see what happens.
What if I just unplug the 02 without disabling in HPT? would this also prove or dis prove?
Old Mar 22, 2016 | 01:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
See what fuel trims and O2 readings look like for each bank. If those are normal then it probably isn't an O2 sensor issue IMO.
You can unplug the sensor to put it into open loop, but I think you have to reset fuel trims after you do that or it will keep trying to use what it remembers from the last time they were connected
I'd log first, check out readings for O2 B1S1, O2 B2S1, STFT & LTFT for both banks (separately) and see what you get.
Old Mar 22, 2016 | 01:54 PM
Dude_man's Avatar
Dude_man
Whatttt youve had hptuners this entire time and havent logged the o2s!?!?
Old Mar 22, 2016 | 01:58 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
HP Tuners can't see O2 readings, geez
To multiple mis-fire APS TT
