Just bought on alky methanol kit for my c6 Z and it is being put on next week. Has anyone used the alky kit with the ECS supercharger setup? If so what kind of gains did you see?
I'm interested to hear the answer to this as well. How much rwhp are you at and how much boost. Has it been boosted for a while? I want to do mine but it makes me a little nervous.
Reason: Mistake
I'm interested to hear the answer to this as well. How much boost rwhp are you at and how much boost. Has it been boosted for a while? I want to do mine but it makes me a little nervous.
Been boosted for about a year now running on 4psi making 660rwhp and 589ft torque.
Just adding Meth is not going to give you any real HP gains. What it does is allows the tuner to give you a much more aggressive tune safely. I had Meth installed with the supercharger by ECS and ended up with 660 rwhp. If I went without Meth the tune would have given me around 560 rwhp.
The ECS meth kit allows for a little more boost. I noticed a 50-75rwhp gain. Definitely worth it and even better if you have them install and have Doug tune it!
You obviously have to tune for the Methanol addition. It will typically allow for 2-3 degrees of additional timing= 40-60 hp.
You have to relocate your IAT as well if you are running a MAF Tune.
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Looks like most questions have been answered here, but I you have any more feel free to ask away.
As for making more power, yes timing can be added once meth is installed, however we have found better longevity from keeping timing down and raising boost. All it takes with an ECS kit is to open up the restrictor plate a little. Two 3/8" drilled holes in it will add approximately a lb on a Z06, if you do not wish to dremel it open.
Hope that helps, feel free to contact us anytime.
Well noted thank you for the advice and I never knew that about the restrictor plate i guess the drill is coming out when I get out of work lol
Just remember that the tune will need to be looked over after adding meth and opening the restrictor plate.
Yes I already have it scheduled to be installed and tuned next week at my local shop and the car will be trailered there so I don't have to worry about it thanks for the help and any other tips Or advice im all ears
