Engine ideas - 800whp range.
Over the winter I did a 3.33 pulley, ID850s (was still 93 only, probably go E85 since they announced 3 new locations ill finally have some local pumps) and last week I did twin 465 fuel pumps from Fore.
Tuning was done, car was running STRONG, was 700whp last year, i suspect obviously a little more than that now. Anyway, something happened and the engine popped. The log looked great right up until the second something let go. Havent pulled it apart yet, in the process of moving to my "forever home" so I dont know exactly what let go. Tuner said a millisecond before it popped a lot of unburnt air went past the driver side 02 sensor, but yet we have oil all over the starter on the passenger side, cant see any visible damage yet, besides oil covering everything.
So I know this is kinda vague, but depending on whats wrong, what route would you take? Leave it LS3 and build it? buy a truck 6.0?
If the block is reusable, Ill stay LS3, but if I build it, should I go lower compression, or leave it stock compression but stronger? Not sure how much more I can get out of my current V2 T-Trim
If the LS3 block is messed up, I dont even know where to start. Budget is a big concern, with buying a new house, this wont be my main priority, so the cheaper I can do this the better, but id like to go with something that can handle around 1000whp to give me a little head room.
Sorry to ramble on, but if the block is toast, im not sure which route to take at all.
Thanks guys.
Sounds like you need to figure out the condition of the block first.
I was originally sticking with 93 due to E85 was nowhere even close to me, now im going to have 3, all about 15 minutes away each.
There was a missive cost saving by going with the lq9 as well. I just dynod my car with a cam that came out of the ls9, tune and an Air raid COI and got 400 to the wheels. For what ever reason, I thought my car was going to sound like a suburban going down the road but I was pleasantly surprised that it still sounds like a vette. The lq9 is almost 100% drop in minus a few things like intake, oil pan and reluctar wheel. You should just beable to recycle most of those parts off your ls3 though.
~Shawn
Not relevant anymore, but did your tuner just follow the (realtime) data from laptop and check again afterwards from the (recorded) log what happened?
But if your just going to build the motor get the LQ-9 or lq4.
Good luck with the tear down. Post up some pictures
Today I did pull the plugs, managed to have 1/2 hour of free time during day light (car is outside under a cover since im using garage space to put all my boxes ive filled up so far).
#7 Spark plug is destroyed. #8 is almost still on piece, but its been hit by something hard.
