C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS steam vent kit?
Old May 10, 2016 | 06:24 PM
usmcpony's Avatar
usmcpony
Default LS steam vent kit?
I'd like to use all four vents to help release pressure and help with better flow. I'd to use braided line or something i can easily bend because I have a vent on the back of the valley cover. Towards the rear driver side. I will need to route around that. Id also like to run it under my PMC intakeThanks
Old May 10, 2016 | 08:58 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
Check out the kit listed below.
C&R Racing p/n 78-10004 LS Steam Line Kit
Old May 11, 2016 | 02:35 PM
neverstop's Avatar
neverstop
I paid too much and got the Kurt Urban kit, mostly because I didn't want to be looking up parts online and maybe get the wrong one, etc and waste time but also because I wanted to ask him some questions and I think his kit is also the only kit where the steam lines come literally straight up from the heads so they should work the best.
Kurt Urban builds some of the craziest LS stuff around too so he should know his stuff.
http://kurturbanperformance.net/home...r-vent-system/
not hard to install. wish I had known when motor was out of the car would have done it then.
Old May 11, 2016 | 06:49 PM
RecMech's Avatar
RecMech
Did mine with Trick Flow fittings in the head and aluminum line and fittings. Bent up easy and all 4 ports can only go uphill til they merge at the front.
Old May 11, 2016 | 06:52 PM
RecMech's Avatar
RecMech
Another view..
Old May 11, 2016 | 09:21 PM
Chris Stewart's Avatar
Chris Stewart
I used a truck coolant tube. GM 12604711, a discontinued part, is commonly found on the 5.3 Tahoe/Silverado. Run some 1/4 fuel line and Tee into the front. All set for about $50.
Old May 11, 2016 | 09:34 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Used truck part on mine too
Old May 11, 2016 | 09:35 PM
algZO6's Avatar
algZO6
nitrous outlet has a nice kit
Old May 11, 2016 | 09:40 PM
usmcpony's Avatar
usmcpony
I took the one off the front and put it on the back. Had to do some bending. I ordered another one today for the front. Im going to run a separate hose from the back to the coolant hose. That way the front and back have their own individual hose running to the coolant line.
Old May 11, 2016 | 11:30 PM
neverstop's Avatar
neverstop
Originally Posted by RecMech
Another view..
that hardline setup looks good
Old May 12, 2016 | 08:14 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Intake manifold have to be off to do this?
Old May 12, 2016 | 08:30 AM
bullitt4110's Avatar
bullitt4110
Yes
Old May 12, 2016 | 08:38 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Nice!
I did this on my C5 when I had it, made my own set-up - really helps things out!
Thanks,Matt
Old May 12, 2016 | 09:12 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Used the Trickflow kit but if I was doing it again, I would just buy the hose and fitting needed separately.
Old May 12, 2016 | 09:39 AM
SquatchMachining's Avatar
SquatchMachining
Drill the steam vent holes and tap them 1/8" npt then just screw in a -4an male x 1/8" npt fitting and use -4an hose and fittings to route it..
Old May 12, 2016 | 10:07 AM
Dude_man's Avatar
Dude_man
I get the idea behind doing this but is there any proven results?
Old May 12, 2016 | 10:41 AM
C6 Curtis's Avatar
C6 Curtis
To look pretty I guess haha. My **** is all stock and I don't have any problems.
To LS steam vent kit?
Old May 12, 2016 | 11:11 AM
SquatchMachining
I mean I can see it helping with cooling the rear cylinders but to be honest the only reason I do it is that it makes it really easy to bleed the coolant system. You never get air pockets with this setup.
Old May 12, 2016 | 11:15 AM
Dude_man's Avatar
Dude_man
That's what I was thinking as well. I have coolant vacuum filler so I never have issues with air pockets, at least that I noticed.
Old May 12, 2016 | 01:16 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Havent seen proof and in theory the engine is higher in the front so any air pockets should make it to there. I just did it because it could help, and definitely couldn't hurt. I also use it to bleed the system. Makes it much easier.
