C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
nitrous tune question.
Old May 22, 2016 | 07:01 PM
LSmustang's Avatar
LSmustang
Default nitrous tune question.
If i have a speed density tuned ls7 zo6 with a iat sensor 6 inches before throttle body and i plan to do a wet shot of nitrous with a nozzle 12 inches before throttle body. Do i still have to run a lingerfelter retard box to retard timing when nitrous is armed or will the iat sense the temp difference and i can tell ecu to pull timing at certain temps? Thanks for help
Old May 22, 2016 | 09:40 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
You can change timing based on IAT reading but when in SD mode the IAT sensor is also used to calculate fueling. Colder = denser air--->more fuel needed. It really depends on how far the IAT reading is going to drop.
How big of a shot are you going with?
Old May 23, 2016 | 04:52 PM
Dude_man's Avatar
Dude_man
You should never spray a wet shot on an IAT sensor. If you want Ill show you how to make a timing retard device for under $30.
To nitrous tune question.
