C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Return style fuel system
Old Jun 1, 2016 | 09:45 PM
travis1746's Avatar
travis1746
Default Return style fuel system
I have the ECS stage 2 fuel system installed with the factory LS7 fuel rail. Where do you place your check valve to keep pressure in the system? Right now I have the check valve just before the fuel rail but the system bleeds off pressure within a minute.
Old Jun 1, 2016 | 11:56 PM
SlowBusa08's Avatar
SlowBusa08
shouldn't the check be after the fuel rails? That would trap the pressure in the rails and at the injectors.
Old Jun 2, 2016 | 08:58 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Where's the regulator in your setup?
Old Jun 2, 2016 | 12:26 PM
badass68's Avatar
badass68
Do you have the regulator block off plugs in the tanks?
Old Jun 7, 2016 | 03:12 PM
Dude_man's Avatar
Dude_man
You want it before the rail, so it doesnt drain back through the pump when the car is off.
Old Jun 7, 2016 | 04:36 PM
Unreal's Avatar
Unreal
Mine is sitting in the garage. Never had an issue starting, fires right up so didn't see a need to install it.
Old Jun 7, 2016 | 04:40 PM
SlowBusa08's Avatar
SlowBusa08
Does the return side have a check in it?
Old Jun 7, 2016 | 07:18 PM
Dude_man's Avatar
Dude_man
No, it doesn't need to. Fuel will only flow past the regulator if the pressure is over your base pressure.
Old Jun 7, 2016 | 07:30 PM
SlowBusa08's Avatar
SlowBusa08
Ah OK didn't realize the regulator was downstream of the rails. Makes sense now.
To Return style fuel system
