C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Boosted C6 MPG question
Old Jun 3, 2016 | 12:46 PM
UmX's Avatar
UmX
Default Boosted C6 MPG question
So I am on a ls2 thats forged with a ecs1500SL - Z06 Pump and Boost a Pump. I have 95lb ID1000s and I am running speed density.
When I cruise on the highway i am getting no higher then say 15mpg and in the city no higher then 8. And that is me grandma driving it.
looking for ideas and what other people are getting
Old Jun 3, 2016 | 01:27 PM
Spoolin8's Avatar
Spoolin8
Ls2 w/ ecs1500 as well. Stock fuel pump with a boost-a-pump, 60lb inject.
With my cam/DRs on a short test i get around 20 on the highway but I cant stay off the gas to get any real numbers.
Old Jun 3, 2016 | 01:35 PM
Unreal's Avatar
Unreal
16-17 city 26ish highway. 1200rwhp 427
Old Jun 3, 2016 | 01:40 PM
UmX's Avatar
UmX
hOWWWWWWWWWWWW lol
why is my **** so wack
your not using the cars computer are you ?
I was doing Miles/gallons put in.
Old Jun 3, 2016 | 02:38 PM
Unreal's Avatar
Unreal
Yes tracking manually.
Blower should not kill gas milleage unless you are on it all the time. Sounds like your tune needs some work.
Old Jun 3, 2016 | 03:22 PM
Detoxx03's Avatar
Detoxx03
I don't really care about gas mileage but even on e85 mine isn't that bad. Sounds like a tune problem for sure.
Old Jun 3, 2016 | 03:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What do you actually get when you add it up manually?
MPG calcs can get all screwed up with tune. Mine shows 2x reality.. so mine shows like 600+ miles per tank on a full tank now
(I'm assuming you were going by DIC with those #'s.. if they are actual then they are low)
Old Jun 3, 2016 | 03:37 PM
Pekka_Perkeles's Avatar
Pekka_Perkeles
So true.
Probably way too little advance. Or runninng open loop all the time. Etc.
Old Jun 3, 2016 | 03:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
But the cool kids run OL the time
Old Jun 3, 2016 | 03:39 PM
Pekka_Perkeles
Originally Posted by UmX
So I am on a ls2 thats forged...
Compression ratio?
Stock or no stock cam?
Old Jun 3, 2016 | 03:57 PM
Unreal's Avatar
Unreal
Low compression kills mpg. Cams kill mpg. Poor tuning does too. Too easy to get into PE is common.
Old Jun 3, 2016 | 04:11 PM
Pekka_Perkeles
...and sometimes tuners forget to activate DFCO after tuning. :-)
Anyway, some cryptic acronyms for OP to consider...
Old Jun 3, 2016 | 04:29 PM
ATLS2's Avatar
ATLS2
I was getting about 33 MPG with the 6L80 highway . ECS kit, cam, 65 pound injectors, and BAP. Now in a 4l65 and stage 1 fuel kit and I'm getting 26 mpg highway.
Old Jun 3, 2016 | 06:13 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
By DIC or calculated?
Old Jun 4, 2016 | 02:09 AM
ATLS2's Avatar
ATLS2
Originally Posted by schpenxel
by dic or calculated?
dic
Old Jun 4, 2016 | 06:26 AM
UmX's Avatar
UmX
I am 9.5:1 and a tick stage 2 blower can.
What is open loop?
And the mpg off the cars computer is never right..
Old Jun 4, 2016 | 08:17 AM
Unreal's Avatar
Unreal
Cam and compression and tuning kill MPG, not the blower or fuel system. Blower and fuel system should have no effect on MPG just cruising around.
To Boosted C6 MPG question
Old Jun 4, 2016 | 08:53 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
What is open loop?
Disabled O2 sensors basically. Could be running lean or rich just riding around and computer can't do anything to fix it. Some tuners leave it like that.. not sure why on most setups.
2006+ have a fuel density table that can be used to get the DIC to display more accurately. Most tuners don't mess with it though
Old Jun 4, 2016 | 10:58 AM
Snowwolfe's Avatar
Snowwolfe
Stock other than the A&A system. Average 20 around town and 28 on a trip running 70-80.
Old Jun 4, 2016 | 11:35 AM
bumpin96monte's Avatar
bumpin96monte
I've been getting about 25-26 mpg with mine lately. That's probably a 90/10 hwy/city split from my commute. In general, I used to get about 2 mpg better when it was stock on the same driving loop, but I do drive it a lot harder after the exhaust and blower.
It's a stock ls3/a6, v3si, catless 1 7/8 headers, corsa extreme exhaust, alkycontrol (I run 50/50, and it's not really cranked up all that much), 65# injectors, a BAP, and a tune.
